Results 1 to 3 of 3
Thread: Formula Rs Price List Update
    apriliaforum Member Formula_Rs's Avatar
    Jun 2007
    Hi guys and girls, this is an up to date price list of NEW parts i can provide, i will have missed some and will add to the list as and when.
    The list contains NEW items and most of the items are GENUINE parts. Some items are stocked, but for the items that are not stocked delivery time is approx 5 days. used stock is kept but its a little akward to keep continual records as parts come and go too quickly and some parts are on bikes etc.
    If you cannot find what your after, fell free to drop me a pm or text or call.
    Best regards Rob @ Formula Rs
    Fairing/Body
    Right side mirror - 24.95
    Left side mirror - 24.95
    Pair of mirrors - 44.95
    Mirror mount - 7.95
    Mirror mount pair - 14.95
    Standard Screen old shape - 34.95
    Smoked screen 95-98 - 42.95
    Standard screen 99-05 - 42.95
    Air duct 99-05 - 17.95
    Outer air duct left old shape - 14.95
    Outer air duct right old shape - 14.95
    Pair of outer ducts old shape - 27.95
    Nose cone - All years and colours avalible - pm for prices
    Bodywork - All years and colours avalible - pm for prices
    Front seat black 99-05 - 57.95
    Front seat red 99-05 - 57.95
    Rear seat black 99-05 - 49.95
    Rear seat yellow 99-05 - 49.95
    Fuel Cap/Lock/Key 92-98 - 54.95
    Fuel Cap/lock/key 99-05 - 89.95
    Fuel Cock 92-98 - 31.95
    Fuel cock 99-05 - 31.95
    Electrics
    Indicator lense orange 99-05 - 6.95
    Indicator lense clear 99-05 6.95
    Indicator lense orange 95-98 - 6.95
    Indicator complete 95-88 - 11.95
    Indicator complete 99-05 - 11.95
    Rear light lense 99-05 - 12.95
    Headlight unit 95-98 - 94.95
    Headlight unit 99-05 - 94.95
    Front brake switch - 12.95
    Rear brake switch - 14.95
    Flasher relay - 14.95
    CDI restricted - 174.95
    CDI full power - 174.95
    Rave solenoid - 64.95
    Rave controll box - 64.95
    Rave Cable - 18.95
    Starter relay 92-98 - 17.95
    Yuasa battery (dry) - 21.95
    Exhaust/Air/Carb
    Air filter sponge - 8.95
    Exhaust flange gasket - 4.95
    Exhaust/end can gasket - 2.95
    Standard expansion pipe (full power)- 119.95
    Standard silencer carbon - 154.95
    Standard silencer aluminium - 144.95
    Jolly moto system with alumin end can - 234.95
    Athena system with carbon end can - 184.95
    Shark system with carbon end can - 299.95
    34mm carb - 174.95
    Front Forks/Yoke
    Top yoke - 104.95
    Fork seal kit 92-93 - 12.95
    Fork seal kit 94-05 - 12.95
    Dust cover ring - 8.95
    Yoke bearing upper - 7.95
    Yoke bearing lower - 17.95
    Frame
    Right side footpeg - 14.95
    Left side footpeg - 14.95
    Pair of footpeg pins - 4.95
    Footrest hanger right - 34.95
    Footrest hanger left - 34.95
    Brake pedel rear - 32.95
    Gear selector pedel - 27.95
    Gear selector rubber - 2.95
    Fairing support bracket 92-98 - 74.95
    Fairing support bracket 99-05 - 54.95
    Center stand - 27.95
    Oil tank cap - 4.95
    Front wheel
    Front wheel 92-98 - 199.95
    Front wheel 99-05 - 199.95
    Speedo drive 92-00 - 38.95
    Speedo drive 01-05 - 38.95
    Standard disc - 149.95
    Front pads - 19.95
    Front wheel bearings - 14.95
    Rear wheel
    Rear wheel 99-05 - 284.95
    Rear disc standard - 99.95
    36T rear sprocket - 19.95
    37T rear sprocket - 19.95
    38T rear sprocket - 19.95
    39T rear sprocket - 19.95
    40T rear sprocket - 19.95
    41T rear sprocket - 19.95
    42T rear sprocket - 19.95
    43T rear sprocket - 19.95
    44T rear sprocket - 19.95
    Rubber cush drive - 38.95
    Rear pads - 19.95
    Rear wheel bearings - 14.95
    10T front sprocket - 9.95
    11T front sprocket - 9.95
    12T front sprocket - 9.95
    13T front sprocket - 9.95
    14T front sprocket - 9.95
    15T front sprocket - 9.95
    16T front sprocket - 9.95
    17T front sprocket - 9.95
    DID chain 520 106 - 27.95
    O-Ring chain 520 106 - 44.95
    Cables
    Speedo cable - 9.95
    Clutch cable - 14.95
    Throttle cable comp - 29.95
    Tacho cable - 17.95
    Dash/Handlebar
    Barrel + lock + key 99-05 - 49.95
    Complete lock kit 92-98 - 124.95
    Complete lock kit 99-05 - 139.95
    Brake lever silver - 9.95
    Clutch Lever silver - 9.95
    Bar end Genuine aprilia black - 7.95
    Left handlebar - 17.95
    Right handlebar - 17.95
    Pair of grips - 9.95
    Swing arm parts
    Upper chain runner guide - 12.95
    Rear shock - 149.95
    Rotax 123 Parts
    Flywheel puller - 18.95
    Flywheel - 219.95
    Magneto - 215.95
    Starter motor bendix - 84.95
    Bendix cover - 17.95
    Clutch plates - 41.95
    Clutch kit - 55.95
    Clutch support plate - 34.95
    Clutch tension plate - 24.95
    Clutch case gasket - 7.95
    Rev counter drive gear - 12.95
    Crank case gasket - 7.95
    Full gasket kit - 27.95
    Top gasket kit - 17.95
    Crank bearings c3 fit - 14.95
    Crank bearings c4 fit - 22.95
    Barrel + piston kit - 219.95
    Carbon reed petals - 32.95
    Balance shaft gear - 16.95
    Con rod kit - 64.95
    KHC piston kit - 29.95
    Mitaka piston kit - 49.95
    Vertex piston kit - 64.95
    Little end bearing - 7.50
    154cc polini bbk - 284.95
    Thermostat - 11.95
    Crank seals - 12.95
    Exhaust/pv blade - 62.95
    Pv case/housing - 74.95
    Pv spring - 3.95
    Pv gasket - 2.49
    Rotax 122 parts
    Flywheel puller - 34.95
    Starter motor - 224.95
    Clutch Plates - 41.95
    Clutch kit - 55.95
    Con rod kit - 64.95
    Water pump impeller - 11.95
    Fuel Filter - 4.95
    Not all parts are listed. if you still cant find a part, dont hesitate to call me on 02380174138 or send a pm.
    apriliaforum expert dellenty69's Avatar
    Dec 2006
    somerset
    are all these GENUINE parts?
    The Hammer - Officialy The Tool Of The Pikey!
    jolly moto, with pollished ally end can!
    standard air box back on. (runs better)
    15 tooth front JT sprocket
    40 tooth PBR rear sprocket (polished)
    xenon HID H1 100watt 5000k bulb
    xenon HID H3 130watt 6000k bulb
    LED White Wedge Inverted Side Light
    peugeot 307 LED flush side repeaters
    bright white halo rings in headlight.
    paint renovation coming up.
    Quote Originally Posted by Cheeseweasel View Post
    Im not judging you, Im telling you your a fucking idiot.
    apriliaforum expert kezajones's Avatar
    Feb 2006
    Guernsey,Channel Islands
    Quote Originally Posted by dellenty69 View Post
    if you consider
    to be genuine parts
    My Bike:
    Vertex Flat Top Piston and VHM Head
    34MM Carb
    JL SS/CF Single
    Skidmarx Double Bouble Screen
    Oxydo Paint Job
    HPI Twin Map CDI
    V Force 3 Reed Block And KTM Manifold
    TNT Power Filter
    Yellow Rim Tape
    Ard Solo Seat
    Renthal Front And Rear Sprockets
    Gilles Black Adjustable Rear Sets
    Galfer RSV Wavey Disk
    Carbon Hugger
    Custom made Braided Brake Hoses
    Stan Stephans Tune (wanktakuclar)
    Ohlins Forks
    Ktm/Beringer Caliper
