Results 1 to 15 of 30
Thread: sprockets/gearing
    apriliaforum expert nopainnogain's Avatar
    Oct 2007
    warwickshire
    sprockets/gearing
    i have a 1989 af1 50 with the minerelli am3 engine(3gears).my fornt sprocket is 12 teeth and my rear 39.in top gear i can reach 12000rpm so i want to change the gearing to give me more top end,am i correct in thinking that my front sprocket is different to a six speed and any ideas where i can get front/rear sprockets.thanks.
    apriliaforum expert Aprilia af1's Avatar
    Jul 2007
    Near Kings lynn, Norfolk
    Hi your font sprocket should be the same as a six speed am6 engine, you can get sprockets etc from http://www.opvoeren.nl/shop/uk/onder...p?Merk=Aprilia
    What kinds of speeds you getting out of your 3 speed as i have an af1 with 3 speed rv3 engine so it's a bit different to yours.
    Oct 2007
    warwickshire
    i never go over 9000rpm in top(3rd)but at that its doing 80kph(50mph)but im only just over half throttle on the flat,it still pulls like a train right up to 12000 but ive not done that often and not looked at the speedo,im no liteweight either (16st)how does that compare to yours.
    apriliaforum Junkie Tuono Boi's Avatar
    Aug 2007
    UK
    Help plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz :confused:
    can some one please tell me about this. on the forum u allways see ppl that say they got lik 14T on front and lik 24T i think on back wat dose this archly do and wats best all so wat do the bikes cum with as standerd ???
    Have Not had the tuono for over 2 years
    Aug 2007
    UK
    Quote Originally Posted by Tuono Boi View Post
    any one help me ?
    Sep 2007
    Ballymoney, Northern Ireland
    from what you got....I'd go for like 13 tooth on the front 47 on the back + new chain
    2001 RS125 Diablo Black Rep - Full Power De-Restricted
    Mods
    Arrow Expansion Chamber - Carbon Aprilia End Can
    16(Sometimes 17)/40 Gearing
    7x5 Number Plate
    Red Top Yoke
    Red Fairing Bracket
    Harris "RS Racing" Red/Black/Carbon Grips
    Black DB Screen
    Pro-X Piston
    Silver Goodridge braided brake line - Rear
    Wish List
    Solo Seat
    Re-spray
    H2KU
    apriliaforum Junkie sheehan's Avatar
    May 2007
    Southend, Essex, England
    any one help me ?
    Right, stock is 12T at the front, 47T at the back.
    Adding teeth to the front increases top end and loses acceleration, Removing teeth increases acceleration and decreases top end.
    Removing teeth from the back increases top end and loses acceleration, Adding teeth increases acceleration and decreases top end.
    HOWEVER adding a tooth to the front does 3 TIMES more than what you would do to the rear, so for example if you put one tooth more on the front, it would be the same as taking 3 off the rear. The bonus of changing the front sprocket is that you dont have to get a new chain, whereas if you change the rear you will have to get a new chain.
    And thats pretty much it lol.
    JOE SHEEHAN
    You only need 2 tools:
    WD-40 and Duct tape.
    If it doesnt move and it should, use WD-40
    If it moves and it shouldnt, use Duct tape.
    Aug 2007
    UK
    Quote Originally Posted by h2ku View Post
    k so if i was to do that. wat would ig et out of it ?
    apriliaforum expert jonesy46's Avatar
    Jun 2007
    northamptonshire
    60-64 or 5, i get bout 68-69 mayb 70 if no wind with a 14t and 19mm carb
    Owner of 06 RS125
    Things done at the moment:
    10mm Rim tape
    Rave unit fitted
    Powervalve fitted
    Derestricted CDI and airbox
    Airblade Black Dubble Bubble
    2007 RS125 Disc fitted
    Forks dropped 8mm
    Renthal ally front and rear sprockets
    Tsubaki x ring gold chain
    Full jolly moto sp exhaust
    Pipercross panel filter
    Wavey Rear disc with sbs brake pads
    Goodridge braided hoses
    34mm polished carb
    Aug 2007
    UK
    Quote Originally Posted by sheehan View Post
    k so wat u think i should get then ?? or shall i just leav it ?
    May 2007
    upto you mate, whether you wanna accelerate fast or have top end speed really. i would say try out a CHEAP 13t front sprocket, and see how it feels. If its nice then fit a more expensive 13t one so it gives better life with your drivetrain.
    JOE SHEEHAN
    Aug 2007
    UK
    kk i need new chain sproket any way the front sporket has gone well wavy lol u now any were i can get them from coz i cant really find any gd sites.
    i know pmtunning and that but any one know any others ?
    May 2007
    ebay matey, gimme a min and i will find you one.
    JOE SHEEHAN
    May 2007
    JOE SHEEHAN
    Aug 2007
    UK
    ty m8t do u ever go up basldon striaght ?
