Page 1 of 10 123 ... LastLast
Results 1 to 15 of 143
Thread: Futura/Capo Flywheel Mod (Lightened)
    37 miles E. of ATX, TX USA.
    This may be old news to some of you but I accidentally discovered today that the RST and ETV have a removable flywheel weight that weighs in at exactly 2.50 lbs?
    I had never noticed this before but while converting an RST engine to be used in a 2003 RSV track bike it became pretty obvious. To convert the RST engine you have to add a cam position sensor (non-machined holes and bosses are already present) and swap over the flywheel and stator cover. You also have to swap to a different front exhaust cam sprocket that has the trigger on it for use with the cam position sensor.
    Just thought you guys might like to add a little acceleration and quicken the throttle response a bit. I have not ever tried this in an RST but we do it all the time on 2004 and newer RSVR's, 2006 and newer Tuonos and of course 2004-2008 Factories.
    Do you really need this? I think not! I rode an RSVR home tonight with the lightened flywheel, love it and think there is really nothing to loose but 2 1/2 lbs of un-needed rotating mass!
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Here are all of the flywheel parts together. You will need to add nuts to the back M8x1.25mm locking types, to keep the sprag clutch in place.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Apr 2005
    O.K. I'll be first... " How?"
    Anything that makes this engine more responsive has got to be an improvement.
    ďThe roadís what counts...donít worry about where itís goiní."
    - Sam Shepard
    -Neil Peart
    apriliaforum expert Arkansawyer's Avatar
    Feb 2006
    At the foothills of the Boston Mountains.
    Quote Originally Posted by The Fixer View Post
    Sounds like a Music City Ride-In mod at the Dugkim Racing Garage........Mojito's optional!
    When in doubt.........power out!!!
    JapseyeOgri said:
    "The camaraderie that very often goes along with Aprilia ownership makes me glad I got one."
    Apr 2005
    Quote Originally Posted by Arkansawyer View Post
    Which will get the revs up faster? A lighter flywheel or a Mojito?
    Do we need a puller? Who's got one?
    - Sam Shepard
    -Neil Peart
    Feb 2006
    Ok....check that. After looking at some of the parts diagrams in the Futura online store section it may be a bit more technical for the DRG(dugkim racing garage).
    Make it two Mojito's and I'll out bench race everybody!
    You need a propane torch and a puller. We sell the pullers in the online store under tools, the torch is something you can pick up at home depot. You want to get the inner prtion of the flywheel up to about 250-300F (without setting anything else on fire or heating the magnets) to ease the separation.
    Take a gander through the RSVR forums...same operation, if cover removal goes well no gasket replacement will be required. I would have one handy just in case. I scored a 50/50 on saving gaskets today
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Jan 2005
    Franklin, TN
    Torch Yes...
    ...puller No. SNAP ONs...check. Compressor...Check. Mojitos...er we can handle that...CHECK!
    I was thinking about doing the chain and sprocket swap, going down 1 tooth in the front. Who wants to do that with me? Besides...at 13,000 miles, i suppose it is getting to be time for this periodic maintenance.
    Feb 2006
    Quote Originally Posted by dugkim View Post
    Gotta pay for my room and board somehow.
    Be sure and have plenty of kerosene ready because if your like me you'll want to clean everything up while we're in there.
    Jan 2005
    Franklin, TN
    Kerosene?
    I'm guessing that must be a good degreser? Honda polish works magic, but I also have some citris solvent that does a pretty nice job. So what chain and sprockets should I buy?
    Connecticut
    It would be interesting to see how this mod would work with the Futura/Capo's already touchy throttle. Along with the increased throttle response you will also have much more engine braking. Riding in slow traffic & parking lot maneuvers would require much more throttle control.
    John B.
    On the bike I am riding right now (RSVR) it makes no difference in street manners but this one has been micro-tuned at AF1 and throttle response is as linear as you are ever going to see on a big twin. It is also 1060cc kitted and cams timed at 108/114 for top end power if that matters?
    I made a few slow speed u-turns and such last night. No issues. You still have a LOT of flywheel weight, equivalent to a same year RSV without the additional 2.5 lbs attached. I like it but it very well may not be for everyone.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Dec 2003
    Merry Land of Maryland
    Quote Originally Posted by bikpaintr View Post
    Uhhhh, John, ever hear of the 05 map?
    Dave
    Feb 2006
    AFAM from AF1 for the sprockets. For the chain shoot FalcoLion an email at his site www.motoworldonline.com and tell him your from the ApriliaForum. Tell him you want the same chain and link that Spencer got.
    Louie's the one who told me about the EK chain and screw type link (no chain tool needed). We've both been very pleased with the results.
    Connecticut
    Quote Originally Posted by commandodave View Post
    Dave
    I've got it along with a PC3 map so my throttle action is ok but not as linear as a carbed bike. What is acceptable on a sport bike might get old on a daily rider you take trips on. I've lightened flywheels before & there are trade offs. The other Aprilias use a different injection system which may be smoother then the Sagem, never ridden a Mille so I can't say. Lighten the flywheel on any bike & the throttle response will be quicker both ways which does require some adjusting too. Considering all the bitching I've read on this forum about the Futura's touchy throttle response I thought it was worth mentioning.
    John B.
