Results 1 to 8 of 8
Thread: I need help setting the Rev limiter on SXV 550 ,,
    apriliaforum prov-nov ADROCK's Avatar
    Aug 2007
    MELBOURNE
    Hoping someone can shed some light on what iam doing wrong trying to set my rev limiter : Tryed this :
    Setting the Red Line Warning Light
    Press and hold MODE and SCROLL at the same time for more than 5 seconds. The display will show "00000"; the first digit will be flashing.
    Press MODE to increase the flashing digit by one unit. Waiting two seconds will advance the cursor by one digit.
    Press and hold SCROLL for more than 2 seconds to store the setting.
    But i can't get it to switch to " 00000 " at all ... do i do it in the odo screen or another one ? , would appreciate any help .
    Aug 2007
    MELBOURNE
    Yeah tried that , but WS appears then disappears and no " 00000 " ?.. i'll give it another go though , thanks .
    Jun 2007
    Norway
    Sorry.. Gave the wrong instructions..
    -Press the Mode And Scroll buttons at the same time for more than 5 sec.. Five noughts (00000) will be displayed in the B area..
    You can find all the info you need, pluss ownersmanualswich describes the rev setting at:
    http://xvasylum.wikidot.com/
    Audun
    Jun 2007
    Norway
    Damn.. Couldn`t get it to work my self.. Have tried before and had no problems.. now I just cant remember how I did it.. Think I followed the instructions in the manual.. but now i cant find it.. sorry.. hope someone else here would give a hand..
    Mar 2007
    Norcal
    Try This.............
    I tried several methods and couldn't get it to work either, I'm suspicious that it might even be different between different bikes, hmmmmmmmm
    Anyway, This worked on mine:
    Turn key to on and scroll to the tachometer screen. (three zeros)
    Push "Mode" and then push "Scroll". (not at the same time like the book says), but still hold both buttons down.
    You should then see the 4 dashes on the screen.
    Let go of the buttons.
    You should then see 08000.
    The first 0 will start to blink.
    Set it to 1 using the scroll button.
    after 2 seconds, it will switch to the next number, which you will set at 0. It will then continue to set the rest of the numbers to 0 by itself.
    Good luck!
    Aug 2007
    MELBOURNE
    Awesome , thanks guys . I'll give it a try when i get home tonight .
    ** IT'S GREAT TO HAVE THIS SITE AND THE PEOPLE ON IT **
    Jun 2007
    Toronto
    This is not the rev limiter this is the red warning/shift indicator light! The rev limiter is set in the computer
    Now RXV 450:CRF 450 R:Yamaha Vino
    Past YZ 250:YZ 125:YZ 125:YZ 125:RM 125
    Aug 2007
    MELBOURNE
    Thanks SAM13 , you were spot on mate . tried it last night and it worked first go . AWESOME . Shame the manual is incorrect ! .
    Sorry Mojo , slip of the terminology ! .
