Results 1 to 3 of 3
Thread: spark plug wire
    apriliaforum Junkie scootertrog's Avatar
    Missouri, USA
    spark plug wire
    I posted this on the "other Minarelli" site but we don't have much action there:
    My freakin' spark plug wire keeps popping off when I hit a bump. The boot is hard plastic and there is a very small horseshoe-shaped wire in the tubular plug sleeve. I have played around with it but to no avail. Who can tell me what is involved in changing out the plug boot/wire (or fix it), and can anyone recommend a good replacement?
    Thanks!
    02 Mz Rx
    70cc Airsal T6
    19mm Arreche carb
    Polini reedblock c/f reeds
    Malossi Multivar
    Technigas Next
    apriliaforum Junkie phidauex's Avatar
    Boulder, CO
    My best guess is that a stock replacement would work fine. 'performance' spark plug wires are usually a lot of hooey, and cost a lot of money. If you really want to fix it, you'd need to bend those little wires in that boot closer together so it forms a tighter grip on the plug, but I'm not sure how your boot is designed, and if you can get in there or not. I'd call your dealer up and have them get you a replacement, it shouldn't be very expensive, and will clear your problem right up.
    peace,
    sam
    Missouri, USA
    Sam, hello fellow Missourian,
    Getting anything from the dealership where I bought it is a total joke.
    I tried to re-pinch the small horseshoe-shaped wire, maybe I can give it another try.
    02 Mz Rx
    70cc Airsal T6
    19mm Arreche carb
    Malossi Multivar
    Technigas Next
  1. Oil, spark plug, moisture & cooling
    By StockMan in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 05-12-2009, 02:40 AM
  2. RXV/SXV Schematic (by popular request)
    By SLORider in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 11-16-2006, 09:41 AM
  3. Is This Spark Plug O.K?
    By DrDeath in forum RS125 Euro-archive
    Last Post: 05-05-2006, 12:49 PM
  4. Spark Plug Change ->NGK Terminal Nut Missing!
    By bt1957 in forum Aprilia and Piaggio 500cc
    Last Post: 04-17-2006, 04:48 AM
  5. Spark plug keeps on failing!
    By 98shaikh in forum RS50 Technical
    Last Post: 07-19-2003, 01:02 PM
