Page 27 of 27 FirstFirst ... 17252627
Results 391 to 404 of 404
Thread: Common problems/issues With RXV/SXV 450-550
  1. #391
    Feb 2009
    Tri-Cities, Washington
    Same symptoms as cam timing 180 degrees out. If problems started after engine work was done, I’d put money on cam timing being set incorrectly.
  2. #392
    Oct 2018
    mexico
    There are no good mechanics hear any idea if there is a video or instructions for that pls let me know in need of help this ios an sos
  3. #393
    Feb 2009
    Right on the first page of the How-To thread...
    https://www.apriliaforum.com/forums/...=1#post2464383
  4. #394
    Aug 2018
    Finland
    Can someone measure dimensions for part 5? Iam rebuilding my engine, and now I noticed there is missing all bushes from head by previous owner.. I will do bushes by myself, so measures needed..
  5. #395
    Westminster, CA - USA
    od = 12.5
    id = 10.5
    l = 11
  6. #396
    Aug 2018
    Finland
    od = 12.5
    id = 10.5
    l = 11
    Many thanks for you!
  7. #397
    Nov 2018
    Spain
    Quote Originally Posted by SXVINWA View Post
    Same symptoms as cam timing 180 degrees out. If problems started after engine work was done, Id put money on cam timing being set incorrectly.
    How is possible to make the timing wrong? the camshafts has an only one postion with the locking holes aligned. Is it right? I am asking because I am rebuilding my engine and I want to do it well.
  8. #398
    Nov 2008
    Western Australia
    Quote Originally Posted by mondraker View Post
    The crank also has to be pinned in the correct position...
  9. #399
    Feb 2009
    Quote Originally Posted by S4R View Post
    ...and on the correct rotation.
  10. #400
    Aug 2018
    Finland
    I rebuilded engine and now I got some fuel problems. When I put start spray to intake, bike starts immediately. And shuts down also.
    I think I have wirings incorrect, where is injectors, airtemp, etc. connectors.
    I checked wiring diagram, and I found correct wire for front injector. For rear injector I dont have wire, like in diagram. Do someone have pics of those right connectings?
  11. #401
    Aug 2018
    Finland
    Quote Originally Posted by Jana View Post
    Problem solved. I think wires are now correctly
  12. #402
    Jun 2013
    Toronto, Canada
    For future reference: http://slorider.com/Aprilia/
  13. #403
    Aug 2018
    Finland
    Again some electric problems. When I hit stator cover with screwdriver (ignition on), for example, bike spins fuelpump, like when you put ignition on.
    Bike doesnt show speed, or load battery while driving... stator doesnt look like it is burned. Can I measure it somehow, or whats wrong..? svx550 -07
  14. #404
    That is normal, they all do that and not an indication of a problem.
    It will even do it when you tap on the clutch cover or the frame, or rattle the footpegs, etc...
