Results 1 to 1 of 1
Thread: Knowledge Repository - SR50 Ditech Tuning
    apriliaforum expert muchacho's Avatar
    Oct 2005
    Let me know if you find any other usefull Tuning Threads
    Part Orders
    Online Stores
    Manuals
    Color Workshop book for the '05-'07 Factory models
    Quick Workshop Handbook (Pre 2005) or List of Many Different Models
    Color Coded Electrical Diagram (Easy to Use)
    Oil
    Agip Cross 2T vs Castrol TTS
    Transmission
    Variator, roller weights and contra spring mechanics for dummies! Learn how it works
    Advice before I change my spring and weights?
    Rollers And Contra Spring
    Torque Spring Slider & Variator Torque Spring Bearing - Didn't fit (pics and dimensions)
    Roller Weight Tuning
    Exhaust
    Read this...before you buy that pipe!
    How the exhaust works
    How much does a pipe do for a DITECH?
    which exhaust?
    Gianelli Reverse
    Tecnigas RS
    Leo Vince ZX vs. Gianelli Reverse
    Engine
    Adjustable fuel pressure mod
    Throttle Body Modification
    Polini and Malossi 70cc
    Malossi Cylinder Modding thread
    Reeds: VL12 or VL14 @ Di-tech (morini)
    BOYESEN reeds - Mission Impossible...
    ECU re-mapping
    Success with TC/70cc BBK/Stock ECU
    Max Feul pressure @ 50 cc
    malossi ecu with 50cc & TC-Unit
    Max's FAQ : 70 mapping ( Malossi ECU or TC-Unit) @ 50 cc
    Crank
    About Crankcases
    Gears
    Installing new rear end gears-STEP BY STEP w/PICS, and performance results!
    Gearing Comparison
    Gearing, Max Speed and 70cc
    Suspension
    New racing rear shock absorber & Performance Ditech rear shocks in stock
    Air Filter
    Shortening length of airbox tube (increase performance?)
    Sparkplugs
    Sparkplug Comparisons
    Other
    Performance parts worth buying
    The Single Best Upgrade Component to Buy for the SR50
    Power Commander
