Results 1 to 4 of 4
Thread: Rear Brake light switch broken
    apriliaforum expert pbigoney's Avatar
    NH usa
    Angry Rear Brake light switch broken
    The rear brake light switch is stuck so the light stays on. I have not dismantled the thing yet but it doesn't appear to be fixable. Any body have a ny clues on repairs??? I have no dealer for hundreds of miles and would have to order in a part. Always a pain in the Butt.
    apriliaforum expert Scotteq's Avatar
    Dunellen, NJ, USA
    It most likely moved so the lever cannot contact it solidly, so it thinks the lever is pressed all the time. It screws in/out of its mount, so you should be able to adjust it back into spec.
    Scott
    Horsepower is an Illusory Equation. TORQUE is real and is the source of all things good!
    It is one of the essential features of incompetence that the person so afflicted is incapable of knowing that he is incompetent. To have such knowledge would already be to remedy a good portion of the offense.
    NH usa
    The plunger does not feel like it is moving. I can pull the lever away from the plunger so no contact. I then discoverd I have to remove the rear cowling to trace the wire so I could remove the switch. At that time it was a beauiful day and said heck on it.
    apriliaforum newb John1000's Avatar
    Oct 2003
    Bristol England
    The bottom of the brake switch is made of soft brass and can bur over causing the pin to sick. Mine was damaged beyond repair and a replacement was hard to come-by so I fitted a calliper banjo with a built in light switch.
  1. Rear brake light, can I get these for the rs?
    By Gearbox Geezer in forum RS125 Euro-archive
    Last Post: 04-23-2006, 05:28 AM
  2. rear brake light problems
    By melv in forum RS125 Euro-archive
    Last Post: 08-23-2005, 08:56 PM
  3. Rear Brake light sensor
    By GPracer123 in forum RS125 Euro-archive
    Last Post: 03-29-2004, 08:57 PM
  4. bolt torque
    By wlk303 in forum SL1000 Falco Forum (all years)
    Last Post: 03-18-2003, 07:34 PM
  5. Brake light switch??
    By Gcookie in forum RST1000 Futura (all years)
    Last Post: 01-04-2003, 11:51 PM
