Results 1 to 13 of 13
Thread: Bike will idle but won't rev up
    apriliaforum Junkie brettray76's Avatar
    Illinois
    I posted this in another list but I need to get this fixed. We are racing this weekend.
    Has anyone had this problem?
    It's a 2006. The bike will start just fine and idle nice. As soon as you touch the throttle it dies. Bam, dead and only gains about 100 RPM. I have checked or changed everything and don't know what else to check.
    Please tell me it's something simple.
    apriliaforum expert AZRen's Avatar
    Apr 2005
    Arizona
    Did you have the airbox off recently?
    08 FE450 Berg
    07 KTM690sm
    05 YZ250
    Illinois
    Yes I did. So when it started this I changed the whole airbox and it still does it. Then I changed the tank in case it was the fuel pump. I guess the throttle bodies are next.
    Jan 2006
    Different bike altogether, but I had exactly the same symptoms when my TPS finally "died" (after a long illness) on my FZ6. Just a thought.
    Hope you get it fixed in time
    Apr 2005
    Arizona
    The only stupid easy thing I can think of that will do that is the bypass tubes. The one closest to the front will fit nicely on the blocked off port on the bottom of the airbox (just in front of where it should be). I don't think it would idle too well though.
    08 FE450 Berg
    07 KTM690sm
    05 YZ250
    Illinois
    Thanks but that's not it.
    I have now changed Ign. box, throttle bodys, gas tank and air box. Nothing has worked yet. Next I am going to change cam and crank sensors. If that doesn't work then the wiring harness and coils. I'll do that in the morning it's 2:00am and I'm tired.
    Mar 2007
    Charlotte NC
    I would suspect fuel pump.
    Russell
    apriliaforum expert dougan's Avatar
    Jul 2006
    Zürich
    I sorta went through this.... turned out to be a "flipped" banjo to the tank.
    make sure your tank/fuel lines are all correctly realined... my only advice.
    I guarantee it is something simple. The bike was fine before you started fucking with it, right...? So, it has to be a line/hose/cable misplaced, or improperly replaced.
    Project Svensk: Husq 510
    Project Centro: SXV5.5
    Project Vader: T07
    Project Vader: Duke II
    Project Vader: 954RR (stolen 2x)
    Project Vader: Speed Triple 2K (crashed)
    1997 KTM 480 EXC w/slicks (crashed)
    1996 HONDA F3 Smokin' Joes (crashed)
    Austin, TX
    is there a power commander on it?
    apriliaforum prov-nov maldos's Avatar
    Mar 2007
    Orange County, CA
    If it's a 2006 isn't it still covered under Aprilia warranty?
    Illinois
    Thanks for the help everyone.
    I ended up replacing the wiring harness with a new one and that did it. We draped a new harness over the bike and hooked everything up and it fired right up and ran great. So then we hooked the old one back up and it didn't work so we just put on the new one and it's fixed. Some where there is a broken wire I guess.
    Alabama
    Hey
    Check fuel pump hoses, They have a tendancy to come loose or crack.
    apriliaforum expert ARAIHEAD's Avatar
    Nov 2005
    409 miles from JOHN 'O GROATS!
    If i knew how to help i would friend.
    The path of the righteous man is beset on all sides by the inequities of the selfish and the tyranny of evil men. Blessed is he, who in the name of charity and good will, shepherds the weak through the valley of darkness, for he is truly his brother's keeper and the finder of lost children. And I will strike down upon thee with great vengeance and furious anger those who would attempt to poison and destroy my brothers. And you will know my name is the Lord when I lay my vengeance upon thee.
