Results 1 to 14 of 14
Thread: Radial calipers on a earlier Mille???
    NitroArgi
    Guest
    Hi Guys,
    Will the radial callipers from a 2003 R fit the Ohlins forks of an early Mille?
    I know that the bottom of the forks is different but what will I need? Is there a way to fit those calipers???
    Regards
    Nitro
    johnmartinclark
    Guest
    re radial calipers
    Try www.qbcarbon.com/products...raking.htm
    They sell K-tech radial brakes and mounting kit for ohlins forks.
    JonC
    Mithrandir
    Guest
    Not that easy
    It is not possible to fit them directly because the mounts are quite radically different. At a minimum you would nee to change the fork caps - but the 3 forks use the race-style external compression adjuster compared to the internal ones of the older forks. I'm not 100% sure that the process can be a simple swap of the caps, because of this. I'm betting that you can't because the mechanisms would be different. Only way you can tell is to find an experienced high-end suspension guy that has had both sets apart and can tell you definitely (or email Ohlins to ask).
    deksawyer
    Guest
    Re: Not that easy
    Nitro, have a look here
    A bit on the expensive side, but very very trick!!
    D.
    NitroArgi
    Guest
    Re: Not that easy
    Derek you are a genius...
    Yoy are right about the expensive bit, however there are two products available:
    <img src="http://www.ema-usa.com/brakes/images/pvmforkbottom_caliper_320.jpg" style="border:0;"/>
    This costs $ 1495.95 and I think that it is tooooooooo expensive...
    But there is a cheaper version (and less trick...),
    <img src="http://www.ema-usa.com/brakes/images/PVM_ohlins_radial_adaptor_r1.JPG" style="border:0;"/>
    This costs $ 395.95!!!
    Now I only need to find a cheap place for radial callipers too...
    Regards
    Nitro
    Maxx
    Guest
    Wheel change as well
    Keep in mind, if you wanted to swap out the 2003 Ohlins with Radial calipers, you will need the 2003 OZ rims as well. They are 5 mm (2.5mm each side) wider at the hub where the rotors mount up then the older OZ or Brembo rims. You maybe able to get away with some spacers behind the rotors, but I do not think this has been tried.
    MaXX
    Yoyo
    Guest
    Mounting Centers
    Watch the mounting centers on the radial calipers. The Brembo Street verion as used on the Aprilia uses a 100mm mount center. The Race Radials use a 108mm mounting center.
    yoyo
    www.racebikeparts.com
    theImmoralist
    Guest
    Ohlins conversion kit
    Supposedly Ohlins is making a conversion kit to allow mounting the radial calipers on the '01-'02 forks. It isn't available yet, but it's supposed to be soon because so many people have been asking this same question.
    rustie6
    Guest
    Re: Ohlins conversion kit
    <blockquote><strong><em>Quote:</em></strong><hr>Supposedly Ohlins is making a conversion kit to allow mounting the radial calipers on the '01-'02 forks.[/quote]
    OOOOoooooo.......<img src="http://www.wpsinc.net/auctionphotos/Gif-Thumbup.gif" style="border:0;"/> <img src="http://www.wpsinc.net/auctionphotos/Gif-Thumbup.gif" style="border:0;"/> <img src="http://www.wpsinc.net/auctionphotos/Gif-Thumbup.gif" style="border:0;"/> I won't even have to machine my "radial caliper ready" gold OZ front rim like Maxx already did (sorry there Maxx) <img src="http://www.wpsinc.net/auctionphotos/Gif-Awcrap.gif" style="border:0;"/> <img src="http://www.wpsinc.net/auctionphotos/Gif-Awcrap.gif" style="border:0;"/> <img src="http://www.wpsinc.net/auctionphotos/Gif-Awcrap.gif" style="border:0;"/>
    Maxx
    Guest
    Like I need radial Calipers!!!!!!!!
    How many miles on your new gold rims?????? I have about 3,000 on mine :rollin: :rollin: :rollin:
    Plus, if you read closely, my guess is if they are making a conversion kit for the 02 Ohlins, you will need the 02 and older rims, machine away!!!!!
    MaXX
    rustie6
    Guest
    <blockquote><strong><em>Quote:</em></strong><hr>How many miles on your new gold rims??????[/quote]
    Hmmmmm, about 3........revs by hand that is (whatever it got when I took it outa the box......STILL don't have the rear yet)
    <blockquote><strong><em>Quote:</em></strong><hr>you will need the 02 and older rims[/quote]
    Yeah......just my friggen luck <img src="http://www.wpsinc.net/auctionphotos/Gif-screama.gif" style="border:0;"/> <img src="http://www.wpsinc.net/auctionphotos/Gif-screama.gif" style="border:0;"/> <img src="http://www.wpsinc.net/auctionphotos/Gif-screama.gif" style="border:0;"/>
    theImmoralist
    Guest
    conversion kit
    I don't know the details of the Ohlins conversion kit yet, i.e. "does Rustie need to machine his new blinging gold rims?"
    My guy at Scuderia talks to Ohlins directly and they told him that there was a kit on the way. I don't know what wheels and offset will be needed, but I'll keep you posted.
    Maxx
    Guest
    Re: conversion kit
    I would machine my rims again regardless of calipers. If I ever did chose to go to Radials (as in 03 spec) I would just add the 2.5mm back behind the rotors with some spacers. Not a big deal. If I decide to buy the conversion kit, my rims are already set up for the 02 spec. That way, I could use them on any bike in the arsenol (if I ended up buying an 03 Mille R to go with the Tuono R ). Or perhaps that nice looking tuono Racing I saw today (but Gold would look stupid on that!!!!!!).
    MaXX
    rustie6
    Guest
    Re: conversion kit
    <blockquote><strong><em>Quote:</em></strong><hr>I don't know what wheels and offset will be needed, but I'll keep you posted.
    [/quote]
    Yeah, just post or email me as to what will be available.
    <img src="http://www.wpsinc.net/auctionphotos/Gif-OrangeThumbsUp.gif" style="border:0;"/> <img src="http://www.wpsinc.net/auctionphotos/Gif-OrangeThumbsUp.gif" style="border:0;"/> <img src="http://www.wpsinc.net/auctionphotos/Gif-OrangeThumbsUp.gif" style="border:0;"/>
  1. Radial Calipers on non-radial forks ...
    By derrickhackman in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 01-15-2007, 06:03 AM
  2. Is the Mille for me?
    By IK_25 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-27-2006, 06:01 AM
  3. Help: Persuade me to Keep the Mille.
    By paulphin2002 in forum General Motorcycle Talk
    Last Post: 05-08-2004, 10:50 AM
  4. Mille -vs- Mille R
    By catalinathunder in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 04-25-2004, 10:35 AM
  5. Kevin Duke's opinions from Parumph
    By clarkie49 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-08-2003, 11:44 AM
