ApriliaForum sponsored by AF1 Racing, inc.
Home  l  Shop Online  l  AF1 Racing  I  Tech Tips   Aprilia Links
Old 10-13-2006, 05:50 PM   #1
Steve / AF1 Racing
Racing SERVICE Competition
Steve / AF1 Racing's Avatar
How do I know if my RSVR has the updated swingarm?
I have attached two photos in hopes of assisting owners of '04 RSVR, and RSVR Factory models who are unsure if their bike has already had it's swingarm repalced.
The bad swingarms have two rivnuts installed on the inside of the chain side of the swingarm.
The good swingarms have only one. Because of the location of the toe guard bracket it can be difficult to see if the second rivnut is present, but you should be able to tell without any dissassembly.
__________________
699 W San Antonio St
New Braunfels, TX 78130
direct:830-626-3966 fax:830-626-3969
Used to have:
'00.5 Mille & '03 RS50.
Currently:
'01 SR50 Two Stroke
'01 RS50 Two Stroke
Steve / AF1 Racing is offline   Reply With Quote
Old 10-13-2006, 07:49 PM   #2
ckruzel
Graphicologist Extraordinaire
ckruzel's Avatar
Send a message via AIM to ckruzel Send a message via MSN to ckruzel
thank you steve
__________________
2010 White RSV4R
Custom Graphics
decal questions? email me at kruzel (at)drippinwet.com / iphone - mobile (at) drippinwet.com
find me on facebook!
making decals for the some of the fastest people on the planet
Josh Hayes | Melissa Paris | Josh Herrin | Jeff Agnes | Dane Westby | Taylor Knapp | Garrett Carter | Chaz Davies | Aaron Gobert | Clinton Seller | Santiago Villa | Corey Rech | Huntley Nash | Benny Solis | Payton Sassaman | M3 Roadracing | Josh Day | AF1 Racing | Van Blaylock | Don Dahl | Brandon Cretu | Cory West | Chris Filmore | Alex Welsh | Elena Myers | Martin Cardenas | Danny Eslick
are my decals durable? just ask the starboyz!
ckruzel is offline   Reply With Quote
Old 10-13-2006, 08:11 PM   #3
gpc111
gpc111's Avatar
Swingarm Question
So please explain the situation...is it a factory recall? or warranty issue?
Where does the problem exsist and what can be done?
gpc111 is offline   Reply With Quote
Old 10-13-2006, 09:50 PM   #4
zedx9
zedx9's Avatar
Gpc111, there is a thread about the entire issue if you do a search but in a nutshell, it's a recall and if you talk to your dealer about replacing it, they will likely order it and install it for you. There is talk of a letter from Aprilia going out to owners but it's been a year since the NHTSB issued the info on the recall and I've not seen a letter. When I asked my local dealer, they said, if you ask to have it replaced, they will do it, if you don't ask, who knows.............mines in and the dealer is waiting for me to drop the bike off.
zedx9 is offline   Reply With Quote
Old 10-13-2006, 10:14 PM   #5
gpc111
gpc111's Avatar
Quote:
Thanks for the details.....Are there any other real recalls...i'm reading about the chain, rear shock...Do you know of any of these?
Thanks Again
Old 10-14-2006, 04:15 AM   #6
marsie
marsie's Avatar
just one question... if the new swing arm only has one hole what does the bottom chain guard bolt up to ? i've looked at my 04 and it has two screw hole's so it something that needs doing so why not it's for free
__________________
marsie is offline   Reply With Quote
Old 10-14-2006, 04:43 AM   #7
novos
novos's Avatar
is 18K miles enough to constitute a "high mileage" swinger to get replaced?
__________________
novos is offline   Reply With Quote
Old 10-14-2006, 04:58 AM   #8
bob57
bob57's Avatar
Is there something to do to transform a bad swingarm into a good swingarm?
a point of welding for example?
bob57 is offline   Reply With Quote
Old 10-14-2006, 05:42 AM   #9
novos
novos's Avatar
no, the lower rivnut causes stress fractures to form in the swingarm, resulting in a large crack eminating from the lower rivnut, hence why they removed it, and replaced it with a simple metal brace.
__________________
Old 10-14-2006, 05:54 AM   #10
bob57
bob57's Avatar
Yes, I know that
but if you simply stop the hole, it can't be bad, no?
I say that because several only-track bikes have simply no access to any warrantly (damaged swingarms after crashes for instance).
Any way to fix the problem without changing it would be appreciated.
Old 10-14-2006, 06:33 AM   #11
Poussin
Poussin's Avatar
I assume a single welding point to fill the hole won't be enough.
What I would do is to weld a square piece of aluminium about 3 to 5 cm each side.
But to do that, you have to know a man who knows is job (a bad welding could cause more damages than the hole itself).
for Marsie : 2 pictures to show you the difference to tie the toe guard.
The "bad" swing arm :
The "good" one :
__________________
2010 White RSV4-R
TTX36 öhlins rear shock
R&G Racing fork sliders and swingarm cotton reels
Cruciata track bodywork
Pro Fiber carbon-Kevlar frame & swing arm cover
Pro Fiber carbon-Kevlar clutch & stator cover
15x41 sprockets
Blue OZ Wheels
Decals by CKruzel
Previous Aprilia bikes
2004 black RSV R Factory
2000 SL Falco
http://www.rsvfactory.ovh.org
Poussin is offline   Reply With Quote
Old 10-14-2006, 10:28 AM   #12
Dr. Thrillride
Dr. Thrillride's Avatar
As I understand it, you provide the VIN and Aprilia checks whether or not the swingarm has been replaced. I don't think it matters whether or not it's a racebike with no warranty. Maybe Steve can confirm?
Dr. Thrillride is offline   Reply With Quote
Old 10-14-2006, 11:14 AM   #13
Ed / AF1 Racing
Max Lean Angle / Administrator
Ed / AF1 Racing's Avatar
swingarms......doesnt matter if its a racebike or out of warranty.....its a worldwide recall to replace all of them
its the only recall in the USA on these bikes. The clutch pump, resetting dash (miles go to 0), and rear brake are all service bulletins, and can be updated if you are under warranty and are having problems.
__________________
Ed Cook AF1 ed@af1racing.com
AF1 Racing Online Store
Ed / AF1 Racing is offline   Reply With Quote
Old 10-14-2006, 11:18 AM   #14
Jack_RSV
Jack_RSV's Avatar
Thumbs up
I asked for infos about swingarm's recall changes and they told me that they left only one bolt/hole....that's what they was talking about!
Crystal....
Thanks a million, Steve!
__________________
"I'm just from the old school where you get on the bike,
open the throttle, go fast, brake later than the next guy,
go fast around the corner and win the race. Why complicate it?"
- Carl Fogarty -
RSVR 04 - a.k.a. BUBI - modlist
- level 2 airbox mods;
- full titanium GPR: wrap in progress;
- high performance titanium clutch discs;
- 520 RK racing chain (16x44);
- OZ rims;
- Satoracing's rearsets black;
- Plastics with CKruzel's decals black;
- Brembo 19x18 brake black;
- Brembo 16x18 clutch black;
- PCIII usb also black (like the blues brothers);
Jack_RSV is offline   Reply With Quote
Old 10-14-2006, 11:18 AM   #15
duc slayer
duc slayer's Avatar
I believe you are DR Thrill and also on the weilding front I can attest to the fact that you want a very certified welder w/lots of aluminuim experience. My first ape was an 01R and like a knuckle head I kust went ahead and ordered a yoshi slip-on (1st non jap bike) and I didn't check the fit, just popped it on and went riding. Wella couple of days later I noticed that the yosh had been hitting the swinger the whole time. So I had it welded, thankfully he was good at his job because it was a veryhard task, that he couldn't get quite perfect. He said that because the alum was so thin that it just kept drawing in, basiclly creating a convex/concave (whichever is inward) hole or divot. it was a little noticable to me because I knew where to look for it.
__________________
#1 Forum Mod Pisser-Offer
Some say a comet will fall from the sky. Followed by meteor showers and tidal waves. Followed by faultlines that cannot sit still. Followed by millions of dumbfounded dipshits. Some say the end is near. Some say we'll see armageddon soon. I certainly hope we will
I sure could use a vacation from this stupid shit, silly shit, stupid shit... One great big festering neon distraction, I've a suggestion to keep you all occupied. Learn to swim!!!
duc slayer is online now   Reply With Quote
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
