ApriliaForum sponsored by AF1 Racing, inc.
Home  l  Shop Online  l  AF1 Racing  I  Tech Tips   Aprilia Links
Old 02-07-2010, 12:17 PM   #1
Bartek
Arrow Need quick help with engine and with bore up gradge...
Hi, I got 2003 Aprilia SR50 De-Restricted with Leo Vince ZX and it's running very well but I will be looking for an bore up grade in couple of months and I need help choosing one, I want 70cc but I have no idea what bore will suit my engine, I think that I have Morini Liquid Cooled engine but I'm not 100% sure, how can I tell what engine I have and if I have Morini then would those bores work???
http://www.adrenalin-pedstop.co.uk/p...03-P-1770.aspx
http://www.adrenalin-pedstop.co.uk/p...CYLI-1079.aspx
And what's the best stock engine Aprilia has used in SR50? there are like 3 different engines...
Thanks.
Bartek is offline   Reply With Quote
Old 02-08-2010, 09:51 AM   #2
Grenadiers
Grenadiers's Avatar
Thanks.
Welcome to the Forum!
You may want to start with the Sticky “Read Me First!” In there you will find tons of very useful information including in the FAQ section the following picture that will help you to identify what engine your SR50 has.
Good Luck!
__________________
"Carpe Diem"
06 Aprilia SR50 (Morini)/Malossi 70CC BBK
ZMR7AP/Mid Grade Fuel w/Seafoam
Foot Deflectors/Rear Rack & Top Case/Mud Flap removed/L.P. mod
Aprilia Racing Shock W/STR8 40mm Riser/HGT Stretch Kit
Norgren F07-200 Water trap W/4AN SS lines/Polished Water Pump
Red HGT Fuel Regulator W/SS Lines/Stage 6-16/49 Primary Gears
20mm Bored-out TBA/VL12 Reed Block/BGM Pod Filter
Polished Aluminium Varo W/Kick start & Pod Filter
HGT Red Brake Levers/L.V. ZX W/red TT sleeve/3° Woodruff key
Dyna Beads/Green Clutch springs/White Contra spring & TC
Malossi Variator/6.5Gr Dr. Pulley Sliders/Stebel Magnum Horn
Grenadiers is offline   Reply With Quote
Old 02-08-2010, 02:39 PM   #3
Bartek
Hi, I had a quick read and found up some kol mods that I might be doing soon but I still need help the the ECU and the 70cc Bore Kit, I got Morini Engine for sure.
The description says that this kit doesn't need new ECU but all threads I read said that ECU must be re-tuned if 70cc bore kit is installed...
So I'm lost now, can I use stock ECU and still have 70cc bore kit from Polini?
Old 02-08-2010, 03:02 PM   #4
dyhorus
dyhorus's Avatar
yes, if you go for the polini one, it has a pressure regulator instead of other ECU like malossi
but malossi is the best, the ECU that comes with it gives more oil and the it is made for 70 cc,
others can explain this better
__________________
morini 2001/stock 50/leo vince RR/multivar/white spring/7g rolers/21mm throthelbody
top speed 60 mph
dyhorus is offline   Reply With Quote
Old 02-08-2010, 03:59 PM   #5
Bartek
So Malossi is better but Polini will work just as well on daily usage?
If so then I will go for Polini when my budget will allow me, thanks.
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
