ApriliaForum sponsored by AF1 Racing, inc.
Home  l  Shop Online  l  AF1 Racing  I  Tech Tips   Aprilia Links
Old 10-11-2009, 09:43 PM   #1
rd400guy
rd400guy's Avatar
Malossi Multivar V2008 testing
(Continuation of this post)
So in addition to the other mods in my signature, here was my transmission setup: Stock variator, 4.5g rollers, and stock contra spring with the Malossi Torsion Control. With this setup, she'd do ~51 mph at 8500 rpm, and could get another 2 mph (9000 rpm) on a long straight/slight decline.
I ordered the Malossi Multivar V2008 (for Piaggio) from HG. It came with 2 sets of rollers, 3.5g and 3.8g, and a purple contra spring, which is about 2" shorter than the stock contra, and is listed at 82%. FWIW, the V2008 uses 19mm x 15.5mm rollers, the same dimension as stock variator rollers.
I installed the variator using the 3.8g rollers supplied with the kit, and the purple contra spring. Took her out. She very easily spun up to 9500 rpm, and accelerated quickly to 20 mph, but then didn't gain much from there. At 9500 rpm, she topped out about 35 mph, and on the same long straight/slight decline, was doing 40 mph at 10,000 rpm. I'm afraid to see what would happen if I put the 3.5g rollers in. It's definintely appearing as though the V2008 really wants a 70cc kit, and perhaps the overrange Malossi Torque Driver and Malossi "special"/long belt.
The good news is, I now have 5 sets of rollers: 3.5g, 3.8g, 4.5g, 5.0g, and 5.3g ('09 stock weight). And I have 3 contra springs at my disposal, Malossi purple, Piaggio stock, and Polini white.
I'm gonna have to order or make a variator locking tool, and perhaps the clutch tool, as it looks like I'm gonna be doing a lot of transmission tuning in the next few weeks. But alas, winter is very rapidly approaching (hard freeze warning tonight). So my scooter tuning days are numbered.
So, thanks to the Multivar V2008 using the same dimension rollers, using 6 of the same weight, or 3+3, I now have the following roller weights available to me: 3.5, 3.65, 3.8, 4.0, 4.15, 4.25, 4.4, 4.5, 4.55, 4.75, 4.9, 5.0, 5.15, and 5.3, couple that with the three different contras, I have 42 total combinations I could try.
I could be at this a while...
__________________
2009 SR Factory (Piaggio - US version) - black
De-restricted; 2.8.0 Development mode; 91+ octane fuel; AGIP City 2t; Amsoil MTG
Tecnigas RSII; Malossi VL13 reed block / carbon; NGK ZMR7AP indexed; Kobalt water trap with 3/16" ID lines;
Malossi Multivar V2008; 5.75g (composite) rollers; Malossi Purple Contra Spring; Malossi Torsion Control
De-stickered; Sidestand; Aprilia racing shock; CRG Blindspot bar end mirror
Top Speed: 56 mph / 90 kph (flat, 9000 rpm w/6.15g rollers)
rd400guy is offline   Reply With Quote
Old 10-12-2009, 12:49 AM   #2
High-Gain SR50
Aprilia Forum Moderator
High-Gain SR50's Avatar
Your not compressing the contrast spring and revving a little on the high side. Start increasing the roller weight a little at a time.
__________________
http://www.HighGainTuning.com
HGT PFI Fuel Induction System / HGT Turbocharger system / HGT Fuel Pressure Regulator / HGT Frame Stretch / HGT Brake Levers
26mm BING Throttle Body / Hebo Manston Racing 70cc BBK = 64.9cc displacement / Malossi ECU / Malossi HPC Full Circle Crankshaft / Malossi Multivar 2000 / Malossi Special belt / 4.5gr Dr. Pulley rollers / Malossi Red Contra Spring / Malossi Delta Race Clutch / Malossi MHR VL14 Reed Block / Engine Block Matched Ported and Polished
80mph @ 11,000 rpm
High-Gain SR50 is offline   Reply With Quote
Old 10-12-2009, 04:29 AM   #3
onu123
onu123's Avatar
I have about the same variator. Only a bit older model.
You probably need to go with the heaviest you have (5,3).
Maybe even need heavier ones.
Using a lighter contra may result in belt slipping.
__________________
Aprilia SR50 Factory 2007 (Piaggio engine):
Gas: 98
Oil: Castrol TTS.
Cylinder kit: Stage 6 StreetRace 70ccm, Stock modified head.
ECU: Stock (un-known software) + Malossi TC (Delivering a tiny bit too much fuel, but i don't want to take it off.)
Crank: MHR HPC
Exhaust: Gianelli Reverse
Air intake: MHR VL13 & Malossi red filter.
Variator kit: MHR Overrange (7.2 g rollers, Piaggio stock contra)
onu123 is offline   Reply With Quote
Old 10-12-2009, 09:00 AM   #4
rd400guy
rd400guy's Avatar
Quote:
Yeah, this is what I'm planning. But if the heavier rollers (3.8g) that come with the variator can't compress the spring that also comes with the variator, makes me wonder where you would use the 3.5g rollers. I guess I'm wondering why they'd include such light rollers, if they're not up to the task.
For what it's worth, it didn't seem like it was making much more power at 9500 rpm, but the butt dyno probably got confused since speed was so low; it's not a very sophisticated measurement / testing tool.
5.3g came stock in my '09, and my acceleration was pretty bad. Which is why I originally went to white contra.
I was also thinking about belt slipping. How do I tell / confirm belt is or isn't slipping?
Since I was getting 52 mph @ 8500 rpm with 4.5g and stock spring, I was thinking perhaps trying out the Multivar with 4.5g and stock spring - just to do an apples/apples comparison on the variator itself, with no other changes complicating the matter.
I was also gonna aim at the 4.15 / 4.25 / 4.4 combos with the purple spring, since they're a little lighter than where I was so I might get up to the 8750-9000 rev range (where she seemed to put out the most butt dyno power), and with the lighter-than-stock purple spring, I'll still be able to spin out the rollers and get top speed.
Next question, opinions: which'd be cheaper, just buy the variator locking tool and clutch tool, or fabricate them?
__________________
Old 10-12-2009, 09:04 AM   #5
shrubman
shrubman's Avatar
I've got mine in place with the BBK and the black (lighter) rollers. Once I get my new outer pulley (probably tomorrow) I'll be doing a road test. I'm eager to compare results!
__________________
Shrubman
2009 SR50 R Factory
Full Derestriction/Dev Mode
Malossi 70cc kit (TC Unit)
Malossi HPC Crankshaft
Malossi Multivar 2000 MHR Team (2008 Model)
Leo Vince ZX Exhaust
High Gain Tuning "Fuel Tune Replica" Regulator
Moto Tassinari VForce3 Reed Valve
Watts F504-02AH Water Trap
Top Performances 3° Advance Timing Key
NGK ZMR7AP Plug
HGT Billet Aluminum Brake Levers
shrubman is offline   Reply With Quote
Old 10-12-2009, 09:23 AM   #6
onu123
onu123's Avatar
Quote:
Buying them is a great idea.
Also see this topic about home-made stuff.
http://www.apriliaforum.com/forums/s...d.php?t=188720
__________________
Gas: 98
Oil: Castrol TTS.
Crank: MHR HPC
Old 10-12-2009, 01:00 PM   #7
High-Gain SR50
This kit also fits the carbureted Piaggio's that can be tuned to turn 12k-14k. That creates a lot more force than a DiTech turning 9k
Not so much power but after you get it to where the contrast spring is compressing all the way, a smoother transition and little higher top speed
__________________
80mph @ 11,000 rpm
Old 10-12-2009, 03:37 PM   #8
Sp33d-Fr34k
Sp33d-Fr34k's Avatar
Send a message via MSN to Sp33d-Fr34k
6,1g og more!
__________________
Aprilia SR50R 08 - Spiderman Edition | MHR Teamspeed2 - Ported 47,6mm Cylinderkit | MHR RHQ ROD85 Crankshaft | MHR EPROM Ignition | Stage6 R/T Reed spacer | KOSO Manifold | KOSO 32mm PWK Carburator | Stage6 Double Layer Powerfilter | Stage6 CNC Racing Drive | Stage6 R/T Reed Valve | Yasuni C21 - Black Edition Exhaust | Malossi Multivar 2000 Variator @ 3,2g HT Rolls | Malossi Blue 106% Contra-Spring | Malossi Delta Clutch - Black Malossi Clutch Springs @ 10.500 RPM | MHR Wingbell | MHR Kevlar belt | Malossi Torsion Controller | Malossi HTQ 14/39 Primary Gearing | MHR Torque Drive | Doppler Gen3 Power Box | Kiesler Waterpump | NGK B10EVX Sparkplug | NGK Silicone Sparkplug Wire
Sp33d-Fr34k is offline   Reply With Quote
Old 10-13-2009, 12:12 AM   #9
SilverSurfer
SilverSurfer's Avatar
Send a message via AIM to SilverSurfer
I think the torsion-controller is what could be throwing things off. I think the torsion controller makes it so you need a slightly heavier set of rollers....?
I'm gonna take a stab in the dark and say: try 4.25grams
...and I'd just say you should get the correct tool....
__________________
check out some of my music
http://acheband.com/
SilverSurfer is online now   Reply With Quote
Old 10-13-2009, 03:57 AM   #10
Sp33d-Fr34k
The Torsion controller does nothing!
You just cant use 4g on the MHR variator on a sport setup. 4g would work if the setup was like a good mid-range 70cc..
You dont compare stock variator with multivar.
You guys with the factory SR deals only with sport equipment. My opinion is that the Multivar 08 aint worth the money to put on a SR with a stock/sport cylinder and a sport exhaust like the ZX,Reverse etc.
Stock variator on piaggio engine is very good! If you own the SR minarelli a multivar would be a much better upgrade
__________________
Old 10-13-2009, 04:30 AM   #11
benzina
benzina's Avatar
I would try this ^^^^
__________________
2006 PIAGGIO NRG POWER PUREJET
Piaggio PureJet Engine 50cc (C452M) (OEM)
Fully De-restricted
Malossi Brake Pads
Malossi Special Belt
Malossi (Winged) Clutch Bell
Malossi White Contra Spring
Malossi Multivar 2000 Variator (7.2g rollers)
NGK (ZMR7AP) Platinum Spark Plug (Indexed to 12 o'clock)
Michelin Pilot Sport Tyres (R)140/60X13 (F)130/60x13
Premium Octane (95) Ron Fuel
Castrol TTS (Fully Synthetic) Oil
Piaggio Group S-Bend Performance exhaust (OEM)
Performance: GPS/SpeedoHealer Accurate 0-50kph (7.5sec) Top-Speed (90kph)
benzina is offline   Reply With Quote
Old 10-13-2009, 04:55 AM   #12
onu123
onu123's Avatar
Oh gee...
I just got my "BBK" on and i'm using 7.2 gram rollers with piaggio stock contra.
And it's still pulling very very strong.
With 6.35 g combo it over-revved.
Anyways. You have a different exhaust and probably other things differ too.
__________________
Gas: 98
Oil: Castrol TTS.
Crank: MHR HPC
Old 10-13-2009, 10:03 AM   #13
rd400guy
rd400guy's Avatar
Quote:
I'm "jumping around" a bit: I decided to go with 4.15g in the Multivar, and keep the purple spring in. I got it all set up last night and was gonna test it; alas, when I opened the garage door there was a cold rain falling. My logic is that 4.5g wouldn't get me over 8500 rpm regularly, and on the rare instances when she did, she seemed a little stronger up to 9k. So I'm "targeting" 8750-9000 rpm. I'll see if the 4.15g will do it, if she overshoots 9k I still have 4.25 and 4.4g combos to try. If acceleration is too bad but revs are right, I'll put the stock contra back in (and probably have to go down a notch on roller weight combo).
Oh gee...
Yes, and I'm still running only 50cc cylinder.
BTW, I fabricated a clutch tool last night:
1/4" x 3/4" x 3' steel stock, cut a piece 15" and one at 8".
5/16"-16 x 1" hex head and corresponding nylock nut for pivot (through 5/16" hole in each piece).
(2) M7-1.00 x 25mm hex heads for the "pins" that hold bell/clutch; drilled 15/64" hole in end of bar stock and tapped to M7-1.00.
The whole project was $9 and change, all raw material / hardware bought at Lowe's, and I had the drill bits and tap.
Used it last night just to see how well it worked. Now both the clutch nut (34mm) and bell nut (15mm) are properly torqued to factory specs: 34mm clutch nut = 55-60 Nm (40-44 lb.ft.), 15mm bell nut = 40-44 Nm (29-33 lb.ft.).
There's enough steel stock left over for me to fabricate a variator locking tool, as well. I'm planning on drilling holes to match the transmission case holes, then carefully using the Dremel to match the variator teeth.
__________________
Old 10-13-2009, 10:23 AM   #14
Grenadiers
Grenadiers's Avatar
PICS!!!! Show us the money!
Sounds like a sweet build!!
__________________
"Carpe Diem"
06 Aprilia SR50 (Morini)/Malossi 70CC BBK
ZMR7AP/Mid Grade Fuel w/Seafoam
Foot Deflectors/Rear Rack & Top Case/Mud Flap removed/L.P. mod
Aprilia Racing Shock W/STR8 40mm Riser/HGT Stretch Kit
Norgren F07-200 Water trap W/4AN SS lines/Polished Water Pump
Red HGT Fuel Regulator W/SS Lines/Stage 6-16/49 Primary Gears
20mm Bored-out TBA/VL12 Reed Block/BGM Pod Filter
Polished Aluminium Varo W/Kick start & Pod Filter
HGT Red Brake Levers/L.V. ZX W/red TT sleeve/3° Woodruff key
Dyna Beads/Green Clutch springs/White Contra spring & TC
Malossi Variator/6.5Gr Dr. Pulley Sliders/Stebel Magnum Horn
Grenadiers is offline   Reply With Quote
Old 10-13-2009, 10:32 AM   #15
rd400guy
rd400guy's Avatar
Used it last night just to see how well it worked. Now both the clutch nut (34mm) and bell nut (15mm) are properly torqued to '09 Piaggio factory specs: 34mm clutch nut = 55-60 Nm (40-44 lb.ft.), 15mm bell nut = 40-44 Nm (29-33 lb.ft.).
It ain't pretty, but it works. If I'm bored some day, I'll slap some paint on it and maybe that rubber handle dip on the handle end.
__________________
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
