ApriliaForum sponsored by AF1 Racing, inc.
Home  l  Shop Online  l  AF1 Racing  I  Tech Tips   Aprilia Links
Old 06-02-2009, 11:27 AM   #1
styx
styx's Avatar
Location: Bedale, North Yorkshire / Riyadh, Saudi Arabia
V4 cutaway engine
Click on the first picture, when the second picture has loaded click again for super close up.
http://www.superbike.co.uk/news/Apri...ws_283636.html
__________________
Steve
When the eagles are silent, the parrots begin to jabber.
Winston Churchill.
styx is offline   Reply With Quote
Old 06-02-2009, 12:25 PM   #2
TRexRacing
TRexRacing's Avatar
Hmmmmmm...............progressive intake valve springs.
__________________
It's only a small world if you don't have to walk home.
TRexRacing is offline   Reply With Quote
Old 06-02-2009, 12:44 PM   #3
azboy
azboy's Avatar
Quote:
They look very similar to the outer VTEC intake and exhaust springs from the Honda V4 VTEC engine. Very similar progressive winding. But I'm sure that is the only similarity between the two....
azboy is offline   Reply With Quote
Old 06-02-2009, 12:51 PM   #4
amauri
just another Aprilia fanatic
amauri's Avatar
Very common actually, the V990 has had them since 1998.
__________________
Aprilia of Long Beach 562 216-7280
amauri is offline   Reply With Quote
Old 06-02-2009, 03:44 PM   #5
Tifa
Tifa's Avatar
they'll never get that motor to run smoothly....there'll be no compression with all that missing metal....
Tifa is online now   Reply With Quote
Old 06-02-2009, 07:16 PM   #6
Silver-Bolt
Silver-Bolt's Avatar
Kind of interesting that the outer case (brown) cover is structural. Must be bearings to support the starter gears? Not much room between the air box lid and the stacks.
Silver-Bolt is offline   Reply With Quote
Old 06-02-2009, 08:50 PM   #7
LUCKY DAVE
LUCKY DAVE's Avatar
Just how much cam timing adjustability do you need? With that much, you could probably make it run backwards!
__________________
A finish is a win! Moderation is the key! More wine! And never lend a faggot your hat
That's 1000 horses per side with blowers AND turbos, Marc.......
'04 Tuono
7 other bikes
LUCKY DAVE is offline   Reply With Quote
Old 06-03-2009, 01:48 PM   #8
amauri
amauri's Avatar
Quote:
The two intake cams are connected to the crank via chain/sprockets.
The exhaust cams are driven from the intake cams via gears on the opposite end.
The slots you are referring to are for alignment but not for degreeing in the usual way, because it would not allow adjustment of IN/EX independently.
__________________
Old 06-03-2009, 09:28 PM   #9
duganc
duganc's Avatar
The cutaway shows some opportunity for cleaning up the cast head ports.
__________________
"I feel strongly both ways."
'01 Mille Blue (one of 27) chassis #117 - Mods (let's just say a bunch)
Former rides:
'92 VFR750F
'89 NT650 Hawk
'63 CB77 Super Hawk
duganc is offline   Reply With Quote
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
