ApriliaForum sponsored by AF1 Racing, inc.
Home  l  Shop Online  l  AF1 Racing  I  Tech Tips   Aprilia Links
Old 12-27-2006, 08:17 AM   #1
amauri
just another Aprilia fanatic
amauri's Avatar
I decided to post this list because I receive so many PM's from people wanting to know about ECU maps, ECU software updates and PC3 confusions.
This only applies to 04-09 RSVR & 06-09 Tuono equipped with the Siemens/VDO engine management.
Map-1 or Map-2 and exhaust:
Aprilia included the option of switching the ECU mapping between two modes.
Engine variant 1, aka Map-1 and engine variant 2 or Map-2.
The bikes are shipped with Map-1 enabled as standard.
This is a closed loop mode that uses the Lambda exhaust probe to help maintain a lean A/F ratio for low exhaust emissions. This mode is tuned to work with the stock mufflers and Cat converters.
Map-2 is for use with racing mufflers and without Cat converters. It is tuned for performance and is not emissions friendly. It does not use the Lambda (runs in open loop mode).
Though it is not used, the probe must remain connected.
Switching between the two modes is only possible with the AXONE or the Navigator.
ECU Software updates:
The software or firmware in the ECU can also be updated whenever Aprilia releases a revised/improved version.
Each of these software updates can be switched between Map-1 and Map-2.
After updating the ECU, the Throttle Bodies may need to be re-synchronized and idle fuel mixture adjusted with a CO meter if you have an 04 RSV with the very ealy ECU software.
Be sure to probe each cylinder at the header test ports (not at the muffler outlets).
There is a password available only to dealers, this password allows access that will permit adjusting the individual cylinders fuel mixture with the AXONE. On some bikes, this may improve how the throttle responds from idle to midrange.
The AXONE checks to see if you have selected a compatible map before proceeding with the update. It will not allow loading software versions not meant for that model bike.
ECU software versions:
The latest AXONE software currently available is 7.0.1 and includes all the maps listed bellow:
software for early 04-RSVR with three wire timing sensor, AXONE ≥ 5.0.4
-664582 was the first generation map, ran poorly when switched to map-2
-664584 (file VD5G684$.BIX) first update and worked very well (first available with AXONE 5.0.2)
-664586 (file VD5G68B$.BIX) same as the map shipped with 2005 bikes
-664588 (file VD5G68Z$.BIX) map specifically to work with the EVO-6 race only pipe
software for later 04-RSVR with two wire timing sensor and 05-RSVR, AXONE ≥ 5.0.4
-664583 (file VD5L683$.BIX) same as 664584, originally installed in the later 04 bikes
-664585 (file VD5L68A$.BIX) same as 664586, originally installed in the 2005 bikes
-664587 (file VD5L68X$.BIX) same as 664588, for use with EVO-6 pipe
software for 06-09 RSVR, requires AXONE ≥ 5.0.6
-266536 (file VD5L980$.BIX) originally installed, no updates currently available
-266538 (file VD5L981$.BIX) for use with EVO-6 pipe
software for 06-Tuono (US 07), requires AXONE ≥ 5.0.6
-266531 original map shipped with early production, had issues with throttle response
-266532 (file VC5L980$.BIX) is the first update
software for the 07- 09 Tuono (US 07.5), requires AXONE ≥ 5.1.1
-266533 (file VC5L981$.BIX) original map shipped
-266534 (file VC5L982$.BIX) for use with EVO-6 pipe
A replacement ECU is usually empty, without any map and must be uploaded with the appropriate map and re-initialized before it is functional.
PC3 precautions:
Before installing a PC3, the closed loop mode must be disabled by switching to engine variant 2 (Map-2).
If you don’t do this, the ECU will sense the modified A/F ratio (via Lambda probe) and attempt to lean it back out.
Since there are so many Aprilia ECU maps, and without the AXONE no one knows what bike has what map, you must be careful when installing a PC3 and downloading a map from Dyno Jet or off your friend’s bike.
The PC3 map is an add-on to the ECU map, a PC3 map from another bike that has down level ECU software will not be correct for a bike with updated ECU software.
Always have your PC3 installed and custom mapped after setting the ECU to Map-2.
I hope this will help clear up some of the confusion.
Amauri
(this info is current as of 05/15/09)
amauri is offline   Reply With Quote
Old 01-06-2007, 04:51 AM   #2
bob57
bob57's Avatar
please, Amauri:
I have a 2005 RSVR, but I was obliged to change the two-wires timing sensor by a three-wires one, because I changed my 05 damaged electrical loom and I found only a 2004 one...
As the connector was a three wires one on the loom, I changed the sensor because ii was more simple for me.
Am I obliged to get a new map from an axone?
I noticed that my engine does not run very well at low rpms...
bob57 is offline   Reply With Quote
Old 01-07-2007, 12:15 AM   #3
amauri
amauri's Avatar
Your ECU is for a two wire sensor and will not accept a map for the older three wire ECU.
I don't know if there are any problems associated with using the old sensor & wire loom with the two wire ECU, I've never tried it.
Your problem with poor running at low RPMs may possibly be fixed by connecting the AXONE and resetting the TPS.
Did you have this problem before the wiring swap?
__________________
Aprilia of Long Beach 562 216-7280
Old 01-07-2007, 03:30 PM   #4
bob57
bob57's Avatar
Quote:
Are you sure? I thought all ECUs were the same...
I tried a 04 ECU (I have one) this afternoon, no difference with the 05 one..
Did you have this problem before the wiring swap,yes?
I don't know, I bought this bike completly broken, the motor did not turn, keys broken, immobilizer broken...so I found a racing loom and tried to fit it but it was a 04, and differences in temperature sensor and this three wires sensor instead of two...
Old 01-07-2007, 05:30 PM   #5
amauri
amauri's Avatar
The ECU's are not all the same.
You can't just swap the ECU without using the AXONE to initialize the system and reset the TPS.
These bikes are not like the old bikes, you must use the AXONE anytime you swap the ECU, TPS, idle control stepper, etc...
__________________
Old 01-07-2007, 05:31 PM   #6
amauri
amauri's Avatar
TPS reset...
__________________
Old 01-07-2007, 05:43 PM   #7
amauri
amauri's Avatar
Quote:
The differences in temperature sensor is not a problem.
The 05 and late 04 uses a Nipondenso sensor, but the early 04 uses a Bosch sensor.
The Bosch sensors are not very good and frequently failed giving false overtemp indication that caused the ECU to go into "Limp" mode.
See this post: http://www.apriliaforum.com/forums/s...ighlight=green
Aprilia sells a connector wire that you can splice into the harness allowing the use of the improved Nipondenso sensor.
The connector is p/n AP8127776
Nipondenso sensor p/n AP0274040
__________________
Old 01-07-2007, 05:48 PM   #8
bob57
bob57's Avatar
Yes, I agree and know that, but does this mean that the 04 and 05 ECUs are different in their electronic structure?
All I heard until this moment is that they are the same, no problem to fit a 04 ECU on a 05 (or 06) bike, you just have to change the map inside.
Old 01-07-2007, 06:38 PM   #9
nashma
Amauri - You have no idea how much I wish this information was available about 6 months ago. Excellent stuff, this sort of info. is invaluable.
Cheers.
__________________
Work Hard, Play Hard, Ride Harder
nashma is offline   Reply With Quote
Old 01-07-2007, 09:21 PM   #10
amauri
amauri's Avatar
I'm sure the "electronic structure" is the same but the firmware is not.
Sure, the 04 ECU will work on the newer bikes, but the AXONE will only let you load the map for that ECU.
Example:
If you look at my list of maps above, you'll see that the correct map for the 06 RSVR is 236536. If you try to load that map on a 05 or 04 ECU, the AXONE will not do it.
That doesn't mean that the bike will not run, but it will not have the correct map.
__________________
Old 01-22-2007, 08:07 AM   #11
MightyMouse
MightyMouse's Avatar
They also make an O2 controller so you don't have to change the ECU to open loop or "race mode" as DynoJet explains it. I may be mistaken on this, but it is what is on their site.
The $50.00 controller is cheaper than going to the dealer for me, since my closest dealer is 6 hours away..
MightyMouse is offline   Reply With Quote
Old 03-29-2007, 06:27 AM   #12
brad black
There is a password available only to dealers, that will permit adjusting the individual cylinders fuel mixture with the AXONE.
Amauri
do you know of any dealers over there or elsewhere that have this password? our importer can't get it, so we can't adjust the co once we've put them on to map 2.
brad black is offline   Reply With Quote
Old 04-15-2007, 11:52 AM   #13
Rapamacha
taking a breather...
Rapamacha's Avatar
I've got an '04 Factory with map 2 & a PC III. Is it really necessarry to update the map if you're running a PC III?
The bike is running just fine, but I was just wondering?
Rapamacha is offline   Reply With Quote
Old 04-20-2007, 11:27 PM   #14
amauri
amauri's Avatar
If your bike is correctly set to Map-2 and your PC3 is also correctly mapped, you should not update the ECU map.
If you update the ECU map you will then have to get a new custom map made for the PC3.
__________________
Old 05-11-2007, 04:43 AM   #15
john in sweden
john in sweden's Avatar
Amauri you wrote:
After updating the ECU, the Throttle Bodies may need to be re-synchronized and idle fuel mixture adjusted with a CO meter.
There is a password available only to dealers, that will permit adjusting the individual cylinders fuel mixture with the AXONE. On some bikes, this may improve how the throttle responds from idle to midrange.
and i wonder the throttel bodie value ,,, and CO value ,,
i have PC3 and custom map,, upgraded firmware with Axone but never adjusting the throttle body and CO ,, but i will soon as i have the values.
i have open air intake with high performence air filter and very open pipes,, if it depending something.
greetings from john in sweden.
john in sweden is offline   Reply With Quote
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
You Rated this Thread:
