Results 1 to 14 of 14
Thread: amount of play in foot controls?
    apriliaforum expert random0082's Avatar
    Jul 2004
    UK
    Question amount of play in foot controls?
    Just wondering how everyone elses are? my rear brake and gear levers have quite a large amount of side to side movement in them. the travel is fine and they work fine, but they do wobble from side to side somewhat.
    What are everyone elses like? im beginning to think that mine have been re assembled at some time without some washers or spacers that should be there? they havent been damaged through a crash or anything so its not that, and the bolts are done up seemingly tight. should they have some kind of washers on them? mine havent. exploded diagrams might help if anyones got any
    Cheers
    Paul
    2000 APRILIA RS125 - Marchesini SP mag wheels, fully adjustable SP rear shock, 34mm Dellorto carb, R&G crash bungs, Carbon front mudguard, 1 piece lightweight ARD race seat unit, Brembo rear caliper, Brembo billet front master cylinder, EBC ProLite front disc
    Quote of the month from Vickers 'so shove it up your gold plated welly-ended fadge and have an orgasm over it'
    apriliaforum expert AndyS_RS's Avatar
    Aug 2006
    www.tjtuning.co.uk/forums
    mine where worn to fuck, more slack than a slapper. The steel bolts rust and quickly begin grinding the alloy away
    apriliaforum expert adam123's Avatar
    Aug 2006
    preston
    mine where crap, just tighten the bolt untill they feel right
    apriliaforum expert Rejimbo's Avatar
    Aug 2004
    Maidenhead, Berkshire
    IIRC, mine had washers on the levers, but there was still a decent amount of side to side movement..... I'd just leave it unless its actually affecting you
    apriliaforum expert samRS's Avatar
    Jun 2005
    North Norfolk, England
    my gear lever is solid but my break lever moves a fair amount if i push it, not enough to be dangerous or something
    My Rides:
    2001 RS125 | 1989 VFR400
    ITS PEANUT BUTTER JELLY TIME!
    You got to have a dream, If you don't have a dream, How you gonna have a dream come true?
    Visit SportsBikesUK.com
    Jul 2004
    UK
    well, like i say, they work fine. i just dont like things being sloppy and inefficient. just wondered if i was missing any spacers or washers that should be there. ill investigate further shortly, not got an allen key that big yet, buy one at weekend, lol!
    Aug 2004
    if you look at the bolt, theres a smaller allen-key slot on the middle of the massive fuck off one lol
    Jun 2005
    Quote Originally Posted by Rejimbo
    not on mine there aint, but ive got a big allen key so it dont bother me
    My Rides:
    apriliaforum expert Gman2005's Avatar
    Sep 2005
    Leciester
    have they got the spacers in them?
    R.I.P Spike
    The smell of two stroke smoke, ummmmm
    I'v almost got my knee down
    Aprilia Yorkshire motorcycle spares and accessories
    Peter Knight
    PJ engineering
    Tj Tunning
    Quote Originally Posted by Stanley_Aprilia
    It needs to be like when a man makes love to a woman, speed and endurance are the key to a wet minge, 2 pumps and a squirt aint good enough.
    RockOil Fully Synthesis 2 Injector
    May the force be with you
    Aprilia RS125
    Aug 2004
    yer, i have a big one, but it got stripped when i came off the bike so i had no way of turning the bolt (ended up using molar grips round the edge of it)
    [EDIT] My bad, that was on me 50 lol, i didnt drop the 125
    apriliaforum expert msta809's Avatar
    Jan 2006
    Bromley, KENT, UK
    there should be 2 washers, one on each side of the lever AFAIK. If its loose add some more washers till its OK.
    apriliaforum Member iluvbikes's Avatar
    May 2006
    Northamptonshire
    Mine have two washers either side and they wear really quickly so yeh you have to replace them quite alot and keep making sure the bolt is tight.
    Sep 2005
    Leciester
    and lub them too
    R.I.P Spike
    Peter Knight
    PJ engineering
    Tj Tunning
    Aprilia RS125
