Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
Thread: How to install an air cooled big bore kit! Step by step w/pics!!!
  1. #31
    Jul 2005
    Great guide! But isn't it easier to NOT split the moped into two parts? I think it's too much work to split it when it's rather easy to change the cylinder... Or am I wrong?
  2. #32
    apriliaforum Junkie damnfunkyhabana's Avatar
    Sep 2005
    brighton uk
    its not that its difficult, its just that there's not much room to manuver on the habana/mojito
  3. #33
    Mar 2006
    anything else i can do?
    Hi i have an aprilia rally 50cc
    I Have derestricted my variator and have a deresticted leovince ZX exhaust. it currently does 55 is there anything else i can do to make its top end faster?
  4. #34
    Sep 2005
    brighton uk
    70cc and gear up kit
    R.I.P
    Taken out by a Tesco's Extra delivery van 13/02/06
  5. #35
    Aug 2007
    Oiltank
    Well that was very helpful. One thing: Oil tank. Is it OK to disconnect oil tank from oil pump? I heard somwhere it should be bleed afterwards because air is not healthy into the system.
  6. #36
    apriliaforum newb baglien's Avatar
    Mar 2008
    Cumming GA / Aquone NC
    Mojito big bore setup
    Looks like this thread has run it's course, but I just got my 2004 Mojito. I swapped out the cylinder, head, piston with the Malossi 42mm kit (70cc), put in the Malossi 19mm carb kit, a Leo Vince pipe, the malossi variator / spring and a Malossi clutch. After doing all this, the performance hasn't really gone up - at least no where near what others are indicating. I've double checked the installation of the big bore it - it looks good. I have the needle in the carb at the 2nd position from the top. It starts great and runs fine, but going uphill it maxes out at 25 mph - down hill max speed is 40.
    Any suggestions are appreciated (if any of you are still out there).
  7. #37
    Jun 2008
    Cool Avoid piston seizure
    Sorry to hear about your luck Baglien,
    I'm an old 2-stroke mx racer/ engine builder and I just wanted to put in my 2 cents worth. Before you go WOT (wide open throttle) down the road on your new engine mods, make SURE you do a sparkplug reading to insure your not running too lean or rich. Check the color of the ceramic on the plug tip. It shoud be a nice chocolate milk color. If its white, its running lean and you could have a piston seizure on your hands in a matter of minutes (even on your first test run!) Also make sure you have no air leaks and she's idling smooth. Excessive high idle can idicate an air leak which can also cause lean conditions ie engine failures. A final bit of my humble opinion...run the best damn 2 stroke oil you can buy. BRRAAAAAAAAAAP!:
  8. #38
    Nov 2008
    how fast does it go with a 70 kit on?
  9. #39
    Nov 2008
    Sue neil
  10. #40
    Jun 2009
    halifax west yorkshire uk
    Quote Originally Posted by scootnfast View Post
    Now you have to remove the piston. There are ring clips located on each side of the connection pin. I used a very small screw driver and snapped it out. Then push the pin out from the other side, being careful not to damage the roller bearing cage.
    how many miles had this bike covered ?
    also
    how many mile is it before a rebuild is recommended ?
    thans
  11. #41
    Sep 2009
    Good tutorial helped me alot
    Piaggio zip 50 4t
    Polini variator
    Polini kevlar belt
    Polini 2g race clutch
    K&N style air filter
    ngk iridium spark plug
    Size 62 main jet.
  12. #42
    Apr 2012
    Swampscott, MA
    Hey piaggiomat, How close is the zip to the fly 4t?
  13. #43
    Banned Snugg's Avatar
    Aug 2007
    Aurora, CO
    Quote Originally Posted by ampb5rider View Post
    You're replying to somebodies comment that is 3 years old and Piaggiomat hasn't been on this forum for 2 years... You might have better luck PMing him
  14. #44
    Apr 2012
    Swampscott, MA
    Opps! What a dope! Thanks
  15. #45
    apriliaforum prov-nov Lynch's Avatar
    Jun 2012
    England - Essex
    hello, Would i have to change anything like fuel/air ratio if I were to remove just the closed off pipes (the ones that were cut off and folded over) ?
    Aprilia SR50 R carb 2009 - De-restricted variator - All stock parts - 6,000 miles - Near perfect condition
  1. How to install a water cooled big bore kit on a SR 50 DITECH! Step by Step w/pics!!!
    By scootnfast in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-04-2010, 12:11 AM
  2. which big bore kit?
    By killerofangels in forum RS50 Technical
    Last Post: 10-31-2006, 08:05 PM
  3. rejetting for a big bore kit
    By jameskrs50 in forum RS125 Euro-archive
    Last Post: 03-30-2006, 03:37 AM
  4. Replies: 18
    Last Post: 12-22-2005, 12:54 PM
  5. Big bore kit on SR50 Factory
    By bikemonster in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-27-2005, 08:22 PM
