Results 1 to 3 of 3
Thread: Question: Hand guard mounting....
    apriliaforum expert Jony2Stones's Avatar
    In the ~Shire
    Talking Question: Hand guard mounting....
    I have questions about installing a set of Pro-Rally hand guards w/ the fat-bar mount kit.
    First off, the stock bar is thick-walled----which prevents the mount from going into the end.
    Second, the brake-side seems to narrow to fit (and clear) the lever....
    Any help would be appreciated.
    "It's broken (btw).......I put it on, it started playing the Beverly Hill Cops theme song --- and then leaked something brown onto my arm........"
    taking a breather...
    Jul 2006
    Palo Alto California
    I ran into the same problem. I used a 9/16th drill and bored out the end of the bar to accomdate the insert. You will need to move your break assy in about 1/8 of an inch toward the center clamp. After that, you should not have any problem.
    I looked at every mounting option at my disposal--including going to a different bar. At this time there is no other option. You must drill the bar or go to a different bar. The bars on the Aprilia are beefy. After mounting I have no issues with vibration etc.
    Kind of a hassle but it works.
    Jul 2006
    I would post photos but nothing so far will let me do so.
