Page 1 of 3 123 LastLast
Results 1 to 15 of 44
Thread: my new bike's finallly arrived!!!!
    Jan 2006
    London
    hey guys its done i have received it today So ive got quite a lot of questions to ask:-they gave me my bike whitout instructions manual is it normal?
    -the bike doesnt idle at ALL im not saying idling 5 sec then cut: as soon as i let the throttle go it cuts lights on lights off engine warm engine cold what should i do==> mixture screw or there is a prob?
    -there was a light smoke of new coming from the brand new exhaust it lasted a couple of miles then vanished is it normal? thank you in advance
    last thing is the throttle is not sharp and precise around idle there is a very big part of the movement(about 30 degrees) that are not opening throttle if you see what i mean... thank you in advance
    Jan 2006
    London
    also i forgot i dont understand they said it was restricted and it goes up to 50mph
    apriliaforum expert Charles's Avatar
    Jan 2006
    1)the idling screw needs twisting clockwise a good few turns. that will sort things out
    2)dont touch the mixture should be fine from stock
    3)the light smoke is fine, that will go whe the bike is warm/run regularly etc...
    4)there is supposed to be some "free-play" in the throttle but 30degs sounds a lot! that needs adjusting to about 1mm free play.
    5)the bike should come with an instruction manual i found it to be very useful so insist they give you one.
    6) if it does more than 50km/h / 31ph on the flat, it is not restricted. are you sure u werent looking at the km digits lol! 50mph is about right although i take it this is a new bike so it should be run in like it is completely restricted for the first few hundred miles...
    Now teaching (electric) guitar! PM me if you're interested and in the Essex/Cabridge area.
    Bike:
    Aprilia RS50 2000
    Mods:
    21mm carb
    gianelli exhaust
    mini front indicators
    (small mk stickers)
    best quote of Q3:
    Quote Originally Posted by Gman2005
    I wouldnt mind my RS being super loud. As long as it gave high levels of performance. LIke having sex really lol
    Jan 2006
    London
    thank you for very fast answer two last little questions. Where is the mixture screw? and i has a last prob i forgot. its the gearbox. getting gears down is very easy but going up between second and third third and fourth fourth and fifth and fifth and sixth they get very very hard to shift is that normal because its new. Ive got very thin basket and my foot is hurt and i have done around 60km
    Banned POD's Avatar
    Dec 2004
    Chicago IL.
    Are you sure they set this bike up for you at all? I would check that it has oil in the transmission if your having that hard of a problem shifting.
    Dec 2004
    Cheshire, England
    If it's brand new it should have the users manual. If it hasn't, insist that the dealer gets you one. If it's 2nd hand you canonly ask, not insist.
    For the other problems, go back to the dealer and talk to him. If there's a real problem, get him to sort it. Teething troubles aern't unusual.
    Rob
    Jan 2006
    Ipswich, Suffolk
    Just ring them up mate, there really helpful (if your the guy who bought from the place i said ) My mate had slight problems like this and they told him how to get around it etc and then sent him the documents so just ask.
    apriliaforum Member GTRalex's Avatar
    Jan 2006
    ENGLAND (east dereham - norfolk)
    congrats on getting your bike mine is being delivered today as well i cant wait
    OWNER OF A 06 BLACK SERIES RIEJU RS2 MATRIX!
    MY BIKE:
    http://www.bikepics.com/members/gtralex/
    2006 RIEJU RS2 MATRIX BLACK SERIES
    FULLY DERESTRICTED
    13/47 GEARING
    SIZE 120 MAIN JET
    MALOSSI RACING EXAUST
    apriliaforum expert samRS's Avatar
    Jun 2005
    North Norfolk, England
    dont forget pics people
    My Rides:
    2001 RS125 | 1989 VFR400
    ITS PEANUT BUTTER JELLY TIME!
    You got to have a dream, If you don't have a dream, How you gonna have a dream come true?
    Visit SportsBikesUK.com
    Jan 2006
    London
    im sending pic very soon. I just called them and they really are helpful. The guy told me the bike is not restricted so that explains my 50mph I think im going to go to a service center for the shift story.the dealer told me he had put some transmission oil inside...how can i check?
    Nov 2005
    Netherlands
    Dude first of all you need the users manual, and they need to make sure the bike runs properly in the first place before selling it to you.
    Jan 2006
    Quote Originally Posted by momo
    i suggest you put some fresh in yourself. not ahrd and there are instructions on the af1 site. basically, right fairing off - (a few allen key bolts), transmission oil out by unscrewing the big bolt on the bottom with a large ring spanner (i think 18/19), unscrew the top plastic plug so no air holds any in, and tip the bike ti it's right hand side with a pan under it to colelct the old oil. tighten up the bottom screw, undo the small one on the side, fill up with fresh til it pours out of that, and then replace botht the plug and the small side screw. sounds so badly explained i know. basically it's worth doing anyway cos of the little bits of swarf casued by the new engine being run in...
    Bike:
    Aprilia RS50 2000
    Mods:
    21mm carb
    gianelli exhaust
    (small mk stickers)
    best quote of Q3:
    Jan 2006
    London
    hey guys where is the idle screwe i looked at the instructions manual pg 57 on the internet and it says you need to remove a rubber plug (i did that) and adjust the scre how do i recognise the screw???
    Jun 2005
    what bikes this? is this a new RS50?
    if so you remove the rubber plug on the fairing (i didnt have one though) and then insert a long screwdriver and it should be there, however on my 16mm carb the idle screw was elsewhere
    My Rides:
    Jan 2006
    Ipswich, Suffolk
    Quote Originally Posted by samRS
    yeh the new old style rs50.
