Results 1 to 11 of 11
Thread: -02 Engine on a -00 Mille??
    apriliaforum newb _basse_'s Avatar
    Jun 2006
    Question -02 Engine on a -00 Mille??
    I´ve been unlucky to have my crankshaft broken on my Mille -00.
    Now, I have found a -02 engine to a fair price. My question is: Does the -02 engine fit without any modifications on my -00 Mille?
    Excuse my english, I´m from Sweeeeden
    apriliaforum Junkie jenspebu's Avatar
    Apr 2005
    near Duesseldorf/Germany
    Hi to sweden
    The answer is YES
    btw: Wellcome to the board!
    cheers
    Jens Peter
    2009 Triumph Speed Triple
    2005 Tuono Factory
    Apr 2004
    Consett UK
    I'm sure there will be people on here who are much more knowledgable on the subject than myself, but, I think you may also have to fit an 02 ECU.
    New Braunfels, TX
    all you need is 2002 EPROM, the ECU and all other electronics is the same
    Ed Cook AF1 ed@af1racing.com
    AF1 Racing Online Store
    Jun 2006
    Quote Originally Posted by Ed / AF1 Racing
    Stupid as I am..... What is EPROM?? Is it software?
    Mar 2004
    Hampshire, UK
    Its a chip with software and mapping tables for the ECU - the chip marked RP58 here:
    If you find you need the 2001-02 chip let me know.... you can have this one for a modest sum (just the chip marked RP58)
    Dave
    apriliaforum expert Aprilia_RSV_Dan's Avatar
    Sep 2005
    Temecula
    Yes it will bolt right in, you can even get by without changing the chip, but the fuel mapping probably would be much closer to being correct with the 01-02 euro chips(02-03 US).
    If the motor purchase falls thru I'm sue you could find someone with a good crank also, I actually have a couple but shipping to Sweeden from the West coast in the US would be to much.
    Mar 2005
    Sweden
    Buster(on sporthoj.com)
    Can make new chip for you..he is cheap
    Jun 2006
    Thanks!!
    Now I have enough knowledge to buy me a new engine
    apriliaforum expert jetfever's Avatar
    May 2005
    Ca
    Diode missing
    Hey, I have an ECU I got used, it does not have the diode between the 2 pins at the top left of the photo ECU.(right next to the screw) The glue (or whatever it is) does not looked disturbed...I wonder what it does?
    Mar 2004
    Hampshire, UK
    Quote Originally Posted by jetfever
    There's a funny thing my other ECU doesn't have one - looks like a resistor to me - soldered and glued.... and the ECU doesn't work properly.....
