Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 120
Thread: Learn how to DE-RESTRICT here!! step by step w/PICS!!
  1. #46
    apriliaforum prov-nov speedo's Avatar
    Mar 2005
    Stockport, Manchester
    Question Peugeot Ludix Blaster - Deristicting
    Hi me and my uncle have had a go at taking the washer restrictor out of the variator on my Ludix Blaster. We had a look and took out the variator, we noticed that there was no washer on the variator! We checked it all over and there was nothing that was washer looking! Could anyone tell me where to go from here? I know that it isnt deristricted because i bought it new from a dealer, and also i get a "jurky" holding me back motion when i go downhill at top speed when doing around 38-40mph. This is what is making me think that it is ristricted! Could anyone tell me what to do now? thanks
  2. #47
    apriliaforum expert NeoGeniX's Avatar
    the Netherlands-Europe
    If its doing 40mph its probably already derestricted. But I've read a story that the new peugeot engines have very slow stock cilinders and its impossible to fit aftermarket cilinderse since the carters are too small somehow. But Im not sure if this is the case for all ludix types. But overall there is very little information about these new peugeot engines and on how to tune them.
    Supermoto Central - 100% Supermoto
  3. #48
    Mar 2005
    Question Belts?
    Yes thats true there is very little to no info on these peugeot's, one thing that me and my uncle found is the size of the belt. As theres no washer on the variator the only thing slowing the bike down is the width of the belt. Its hard to explain but we think the "jerkin" motion is the belt slipping on the top of the variator when at high speed (or downhill). So one way to increase speed is to find a belt with a thiner width in size, this will increase the amount of space its got to rise on the variator with the centrifugal force, this giving you more speed. But can anyone confirm this prediction? Anyone any idea's?
  4. #49
    Mar 2005
    Question De-restricting Ludix Blaster
    I have been looking around for how to de-restrict properly my ludix blaster. I have found a website www.scooter-center.com the website is german but you can change the language etc. Anyway i have found in the peugeot ludix LC (liquid cooled) section a deristricted CDI Unit. They say if i take out my restricted CDI Unit and replace it with this it de-restricts my bike! Just wondering has anyone heard of these CDI things? And could you tell me whats happens when you install one? Cheers
    Happy Days!
    Prillia pOwaaarrr!!!
  5. #50
    Jan 2006
    Unhappy New Mojito custom 50 owner
    I've read all the stuff about de restricting and now at a bit of a loss. Just bought new Mojito custom 50 and was told by the dealer that they would de restrict it for me. My average top end speed on the flat would be about 42mph nearly 50 on a bit of a downhill. The thing is my exhaust looks untouched ie. the bolts are still welded at the manifold join and there's a small diameter tube coming out of the manifold that connects to a rubber pipe with jubilee clips. Is this the pipe that needs cutting off? In the owner handbook it mentions a catalytic converter dont know if that is part of exhaust system or not? So my main question is with the speeds I'm getting does it sound like a derestricted scoot or has the dealer stitched me up? Also does anyone know a good scoot tuner near me (Brisbane, Australia). I need bike to do about 50mph on the flat without too much fuss and expense. Any ideas.
  6. #51
    Ohio
    Hello,
    With those speeds, I would say there is some deffinate de-ristriction work been done... Now, if the weld is still on the flange bolts, then they may not have de-restricted it ALL the way. If you cut the smaller pipe out of the exhaust and the little bent pipe off, you will get a little more performance. It may not all be in top end, but you should see a bit more pep out of it.
    As far as catalytic converter goes, the stock pipe is a catalytic converter. That is why it weighs like 50lbs! Also you may have noticed that after you ride for a bit it becomes VERY hot.
    Touring pipe is good improvement over stock, but if you can get ahold of a nice expansion chamber and fit it on, that would be even better.
    02' SR Ditech - 03' Mojito Retro - 04' Mojito Custom
    Visit Scootnfast.com for lots of scooter tuning tutorials and information!
    ExTremE ScoOTeRs-
    ModIFied fOr PerFoRManCe!!!
  7. #52
    Jan 2006
    Question Whats the best expansion pipe
    Any ideas what is the best expansion pipe for my Mojo 50 custom, and do I then need to change the carb jets or any other mods needed to get the best performance with the least fuss and expense. Also the little pipe that comes off the exhaust doesn't just stop its connected to a round plastic looking container via a rubber tube. Any ideas what that is. cheers.
  8. #53
    Ohio
    Well, they really don't make an expansion chamber specifically for a mojito. You have to do a little customizing to getone to fit. Only touring pipes are available for the Mojito.
    As far as jetting and all that goes, it is hard to say if the dealer re-jetted it or not.
    Read this: http://scootnfast.com/scootnfast/Tun...ance_Parts.htm
    It explains a lot about what will give you performance for your $$$
    ExTremE ScoOTeRs-
  9. #54
    Jun 2006
    Wakefield
    Do these know you have used there information?
    http://www.flexistentialist.org/arch...cting_an.shtml
  10. #55
    apriliaforum newb tomh's Avatar
    Apr 2006
    Blackpool, UK
    Quote Originally Posted by Hoveringpie
    if you'd have bothered to look at it properly, you would have seen that it says ' This document was originally written as a thread on the ApriliaForum by Scott (AKA Scootnfast) and all credit should go to him.'
  11. #56
    Jun 2006
    Wakefield
    Oh yeah soz.
  12. #57
    Apr 2006
    Blackpool, UK
    Oh yeah soz.
    no probz m8
  13. #58
    Aug 2006
    hello ive just brought an 02 sr50 ditech the owner said its been derestricted but after reading some posts here i dont think it has. i can only get about 42 mph on a straight and 45 down a hill so im thinking that no derestricting has been done. is the washer on the variator easy to remove? also i need to find a dealer close to leicester to get the ecu remapped
  14. #59
    Aug 2006
    Aprilia SR50 Factory
    Hiya, i recently bought an Aprilia sr50 factory, and have found your information very interesting and informative. But i have one problem, i cant take the cover off, covering the variator? its the big silver metal thing, i unscrew the screws but it still seems stuck on as though its welded? but im sure it wont be? any feedback on this? much appreciated, dan
  15. #60
    apriliaforum Member richardkemp's Avatar
    Aug 2005
    Wiggle it, whack it, etc, there is a little pin which holds it in place. It will come.
  1. How to install an air cooled big bore kit! Step by step w/pics!!!
    Last Post: 03-03-2013, 12:38 PM
  2. How to install a water cooled big bore kit on a SR 50 DITECH! Step by Step w/pics!!!
    Last Post: 09-04-2010, 01:11 AM
  3. Installing new rear end gears-STEP BY STEP w/PICS, and performance results!
    Last Post: 08-21-2010, 10:57 AM
  4. Spray painting advice
    By paulmeldrum in forum RS125 Euro-archive
    Last Post: 01-06-2007, 11:13 AM
  5. step by step clutch guide?
    By brettking26 in forum RS125 Euro-archive
    Last Post: 06-28-2004, 06:13 PM
