Results 1 to 14 of 14
Thread: Hero blobs
    Gosport
    Hero blobs
    I need a pair of the longer hero blobs that come with the centre stand kit. I've looked on the parts .pdf and can't see them anywhere. Anyone happen to know the parts number?
    I tried ordering by explaining what I needed & ended up with a spair pair of the short ones so I want to order again giving the part number this time.
    mlh
    ... a state of suspended disaster ...
    www.ixion.org.uk
    Mar 2004
    Hampshire, UK
    Er - why do you need them - I reckon they're dangerous. But anyway - if you're deperate you can have mine, always assuming I can find them. They come heroically pre worn!
    One option would be to use a stainless steel hex head bolt maybe with a nut to hold it down or thread lock it. I've put a very short one in that's flush with the foot peg.
    If you get stiffer springs nothing will hit the deck (unless you've fallen off..!)
    CC
    Jun 2004
    south wales
    I never fitted them either. Have never seen any reason to do so since. I'm 99% sure i have mine if you want them ( but will have to check).
    Send me a pm if you want them.
    Nov 2005
    England
    Just to clear the part number mystery - apparently since the centre stand is an accessory, it comes as one part number. You can't order the bits seperately. I suppose this means if you wear out the hero feelers, you've worn out the centre stand, mate.
    Tokidoki
    Jan 2006
    Cheshire, England
    If you don't want to touch the stand down wack the preload up to max. When I got my bike I was forever catching the long hero blobs...got to know the handling within a short time, wacked up the preload and don't have this problem any more. But I am only 11.5 stone and only ride with the a light load in the top box....also no pussy lines, so I am leaning it reet over. Handles better in my opinion and not hard as some people tend to think. Just got to do the fork mod now as front too soft. Will try 15w oil and the plastic pipe for preload mod before buying thew hagon stuff!
    03 Capo
    K&N Air Filter
    Remus GP Pipes(Cats removed)
    Std Cat Map
    Gosport
    Quote Originally Posted by Rave
    I don't like the way it handles when I do that.
    mlh
    www.ixion.org.uk
    Nov 2004
    London
    I was told the hero blobs come with the panniers ?!?!
    If they come with the centre stand, I will see if I can get them and you can have them since I am waiting for a new stand to arrive, and my blobs are fine !
    Gosport
    Quote Originally Posted by monoi
    Well I was supplied with a pair with my centrestand kit. I was in a crash later that year & both footpegs needed replacing (don't ask). the stupid repairers didn't keep the hero blobs.
    [/QUOTE]If they come with the centre stand, I will see if I can get them and you can have them since I am waiting for a new stand to arrive[/QUOTE]
    Thanks but I've already been kindly offered a pair.
    But short enough to allow the centrestand to go down when being, er, 'spirited'. That bothers me slightly. Not much but a bit.
    mlh
    www.ixion.org.uk
    Jan 2006
    Cheshire, England
    Quote Originally Posted by mylovelyhorse
    Play with the damping at the same time. What don't you like about it?
    03 Capo
    K&N Air Filter
    Std Cat Map
    Gosport
    Too solid. Suspension should, well, suspend, not wallop
    mlh
    www.ixion.org.uk
    Gosport
    And now I have a pair because that kind chap Nordboy posted me a pair. What a top chap.
    Thanks very much!
    mlh
    www.ixion.org.uk
    Jun 2004
    south wales
    Absolutely no problem at all. That's the benefit of a forum like this.
    Mar 2004
    Hampshire, UK
    Solution - change the springs for some stiffer/rising rate ones - you be able to set the damping correctly
    CC
    Gosport
    Quote Originally Posted by Captain Capo
    Solution - leave rear shock as it is (front springs are already Touratech), save loads of money, be happy with suspension.
    If I ever get thoroughly bored, I'll do the static sag & all that and try playing with the damping, but not today, methinks.
    mlh
    www.ixion.org.uk
