Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: cilinder kit port maps
    once you go to 205 on ex port you need all the comp you can get
    hebo 3 pipe is outdated ,try one of fat designs ..
    apriliaforum Junkie scootertrog's Avatar
    Missouri, USA
    Cool stuff, beyond my tuning experience but I'm learning. I have a new Airsal T6 and will trace/post it.
    Missouri, USA
    cylinder kit port maps
    Sorry it took so long, but here's a port map of the Airsal T6 (72cc)
    O.K....So how do you get the attachment to show up???
    apriliaforum newb Slash's Avatar
    Braga - portugal
    I have one sr 50 with minarelli motor and 1 year ago I kited my bike...i buy a HEBO cilinder and the rest of the kit is polini...the bike is more faster but is also more problematic...last resivion cost 216...
    Aprilia rullez!
    Missouri, USA
    Micah,
    How come my attachment isn't showing up?
    apriliaforum expert Modular Overrev's Avatar
    Philippines:Land of Guns,Goons & Gold
    here's another portmap, this time it's from a Yamaha Jog scooter which i ported to PRO RACE specs i'll try to post a stock untuned 50cc cilinder when i get my hands on it. this cilinder is tuned for very high rpm drag racing so 14,000 is the nominal rpm i'm striving for.
    port durations are the wildest i've ever made so far so i hope this cilinder works or i have just wasted countless hours of porting & not to mention loads of money for machining & new oversized piston kit.
    JDM 2004 Honda CBR600RR
    Akrapovic Evo full system PC III USB WP 4618 rear shock WP 1508 steering damper Ohlins 0,90 kg/mm fork springs Overrev tuned cartridges Brembo 19 RCS HEL brakelines PF front pads & SBS rear pads DID ERV3 520 chain 15/47 AFAM sprocket Robby Moto quick throttle Euro racing riser plates
    2004 Yamaha Aerox R
    Yasuni C21 MHR Team 6T 70cc kit MHR Team crank Stage6 crank bearings PVL inner rotor ignition Keihin PWK28 carb Malossi VL12 reevalve KOSO manifold Polini Evo SS9 vario Malossi ventilvar Bando belt Polini 128mm rear pulley Malossi Delta clutch Malossi Wingbell Polini 15/42 gear kit Malossi RS24 rear shock Aprilia Rally 12" wheels Bridgestone Racing Battlax tires
    the first pic i uploaded didn't come well so i just deleted the file and made up a new one. i hope it's goes ok this time.
    2004 Yamaha Aerox R
    tiba its not radical except for square exhaust port and width
    i got 50cc cylinders with ex port raised so much it broke out of fins and holed !
    i cut the fins out and welded the hole then rewelded the fins back on !
    i got a cylinder with ex port 17mm from top with transfers 28mm from top with squish so tight piston putting impresion mark on cylinder , timing retarded so much it dont even pull below 11000 rpm , we run them with 17/31 gears on big track so there is some lag at start but after that it flys
    ip2,
    that's why i kept it below 18mm ex port ht. i hate to weld a cilinder so i made my timings a bit conservative so i can raise it a bit later when needed.
    maybe if i get another cilinder i'll try a more radical port spec. you use TJT pipes on the 50 too?
    BTW it's good to know you have some use for the 17/31 gears i sent you, have you used the Malossi primary gears yet on the EVO 70?
    2004 Yamaha Aerox R
    yes using TJT on 50cc too , they are very peaky with power starting at 11000 and lag badly at start with tall gearing .. remind you we are running 215 on exhaust with stock pulies
  1. Need some advice about Ditech Interface Kit
    By Team Norway in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 07-21-2006, 10:22 PM
  2. Craig parts list
    By frantic_2003 in forum RS50 Technical
    Last Post: 06-26-2006, 10:32 AM
  3. 80 kit such a good idea?
    By H.B.J. in forum RS50 Technical
    Last Post: 06-02-2006, 09:59 AM
  4. Underseat space and tool kit.
    By The Mechanic in forum RST1000 Futura (all years)
    Last Post: 07-15-2004, 08:59 AM
  5. Sneak Preview of the Malossi 80cc Kit!
    By Micah / AF1 Racing in forum RS50 Technical
    Last Post: 11-15-2003, 03:07 PM
