Hi all, selling a DR 73.5cc big bore kit cos I need the money. The barrel was only used by me for around 500kms MAX but it is so worth it. Makes it so much easier, especially around town. I can send the jet if needed (cant remmeber size) for a standard 12mm carb that I ran mine with fine.
IT WILL NEED A NEW PISTON
When I fitted the piston I pushed the started button and took a chunk off the edge of the piston (twat i know lol). ANd because of this it has resulted in 2 other pieces coming away from the piton, probably down to unbalanced weight of the piston.
The barrell is spotless and gaskets are ALL reusable except for the base gasket which should be changed but will send with it anyway.
To get this running you will just need a piston (can send this one with it if you wanted to run it but I wouldnt really reccomend even though it ran fine on mine).
I want £40 + delivery (probably be about £5-£7)
Surely a bargain.
The BBK was originally on Dom's (youngun) RS50 for bout 5000kms so has LOTS of life left, been sat in my drawer in my bedroom for bout 2 months now!
ITS PEANUT BUTTER JELLY TIME!
