Results 1 to 15 of 22
Thread: 80cc malossi??
    Jan 2006
    plymouth, england
    80cc malossi??
    because my top end seals have gone and might be a pain in the arse to get
    hold of because of the bb. I have thought of getting the 80cc malossi to
    replace it. would any one recomend it or would you get somthing different.
    I want bigger than 70cc, so i was thinking maybe 75cc top performance or summin! what u rekon?
    Mods to come...
    Exhaust hanger, koso guages
    Mods already done...
    21mm carb and re jet, Arrow system, remote start alarm, 13/43 gearing, tyre paint, Solo seat, db iridium screen, carbonfibre leavers, carbon fibre indicators, carbon fibre bar ends, 70cc big bore, ram-air induction, respray in yellow and blue, 3x airhorns, carbon fibre reeds and performance cage, iridium plug, undertray, plate re print in CF, mk clutch, yellow rim tape, rs grips, wheels re spray in blue, camel track decals, all in one solo seat, carbon fibre mirrors,
    apriliaforum expert olls_1's Avatar
    Jun 2005
    southampton
    you can get one yeah, but when you get it think about how much stress you will put on the bottom end on your engine ( e.g crankshaft and barings). up to you realy but i wouldnt, save up for a rs125!! olls
    apriliaforum Junkie rs1banger's Avatar
    Aug 2004
    scarboro
    my top75(pink) knackered 2 cranks!
    my original crank and i bought the bore kit 2nd hand off a kid who'd snapped his conrod putting a hole in his bottom end
    on the plus side tho it does do 90mph with good reliability now
    so if you get a faster borekit you'd better budget for a race crank and the bottom end rebuild to fit it
    top 75, yasuni hmr2, dellorto 21, malossi inlet, carbon reed, stoppers bent back, timing retarded, polished piston/head/ports, uprated clutch springs, 15 front
    apriliaforum Member divinitygr's Avatar
    Feb 2005
    Ελλάς (Greece)
    my malossi 80cc has just damaged my crank and that very annoying.
    I hope i can fix it soon - my top speed was 120kph (75mph)
    I heared a lot of good things about tp75 red if that helps
    Nov 2005
    Netherlands
    Top Performance 75cc (red) is faster than a Malossi MHR Replica wich is btw. not 80cc but only 76,4cc.
    apriliaforum expert Law's Avatar
    Feb 2005
    Sussex, UK
    yes the malossi kit is about 76.4cc
    The red top performance and the street top performance kit are both 73.5 cc despite there names.
    I am using the street kit for reliability, as it has twin rings and less agressive porting. depends how often you want to replace the rings in your engine and how much efoort you wanna put into maintaining it.
    2004 RS50 2004-2006
    2001 RS125
    CMP panel filter, SS&CF JL single , 34mm carb, Power Valve, V-ForceIII
    ARD Race fairings, DB Black Screen, Iridium indicators, Carbon Fibre, Clear Brake Lens, Pro-Bolt
    Funniest thing ive seen on here so far, directed at tomrobbo03.
    Quote Originally Posted by f3ieky
    Listen mate, you're as useful to this board as a 1 legged man in an arse kicking contest so fuck off to the pokemon forums.
    Nov 2005
    Netherlands
    Exclamation
    Quote Originally Posted by Law
    Red is 49,5mm 75cc exactly and has a single piston ring and has a really agresive port timing, the Black one is 49mm and is 73,5cc with a 2 ring piston and a bit less agresive port timing.
    Jan 2006
    plymouth, england
    so i think i will go for the red. any one now where i can get one of theese?
    Mods to come...
    apriliaforum Junkie iron chef's Avatar
    Feb 2006
    West Sussex
    Quote Originally Posted by addjobe
    .... now where i can get one of theese? ...
    What he said ! ! ! and i dont spose you have any pics of your RS? sounds interesting...
    P.S...and do they do a more suttle silver cylinder and head do they? i try and avoid atention seeking mods...
    P.P.S...What a waste of my 100th post!
    click thy LINK for thy shizzle
    Feb 2006
    oreton,ludlow
    ha dude the 80cc kit aparontly just shakes ur bike to hell and will smash ur botom end, so iv bin told + it ant cheep
    apriliaforum Member slutty's Avatar
    Nov 2004
    Indianapolios
    I have the 80 cc..........@ first had the single ringer then went with the double....Im on piston # 2 due to the first time oil injector took a dump.....and the second was from ????? the cylinder has a small score in it from the first blow.....and still ran fine for piston #2 we will see how it does with piston #3...I noticed alot more power with the single ring vs the double but the double last like 10 X longer.........I cant compar it to any other cylinders but than stock.......So, Im happy with it...just got to find a crank to stick back in it ....then Some acuguages are definatly in order to prvent any detonation in the future.
    2003 YAMAHA R1 For sale...........Black and flame.........$7800
    apriliaforum expert Tybersk8er's Avatar
    Jun 2005
    Flagstaff, Arizona Rides: rs50
    Quote Originally Posted by iron chef
    pics
    Here's my pink TP 75...
    http://www.bikepics.com/pictures/388946/
    Pictures of my rs50
    Engine Mods
    Malossi 80cc Street Kit
    Barnett Racing Clutch
    13/47 gearing
    Leo Vince V6 Exhaust
    Mikuni 24mm Carburetor
    Carbon Fiber Reeds
    Engine Fan
    Visual Mods
    Flushmount turn signals
    Headlight mod
    Custom Black and Yellow Dials
    STOCK RS50 EXHAUST FOR SALE
    Banned RiejuR51's Avatar
    Jan 2006
    Essex
    Quote Originally Posted by Tybersk8er
    not that you will be able to see it once ur fairing is on, and your engine is so clean! on my rieju the engine is more exposed so it gets dirty n starts to corrode, im not happy!i want my engine looking nice bt theres not much point when it just gets dirty straight away
    Feb 2006
    West Sussex
    WHERE DID YOU BUY THEM FROM????
    i cant find them in england and i cant find a parts list from craig...
    apriliaforum expert samRS's Avatar
    Jun 2005
    North Norfolk, England
    search for CMP pricelist, there should be a topic made by 'carl' with it in
    My Rides:
    2001 RS125 | 1989 VFR400
    ITS PEANUT BUTTER JELLY TIME!
    You got to have a dream, If you don't have a dream, How you gonna have a dream come true?
    Visit SportsBikesUK.com
