Results 1 to 11 of 11
Thread: Chip, where is it???
    apriliaforum Member squirrel's Avatar
    Mar 2005
    Rabun Gap, Ga.
    I just mounted my new Falco Fighter cans and now i need to replace the old chip with the new one, where do i look for it? Thanks in advance.
    Sydney, Australia
    Under your seat is the ECU box. Disconnect 2 connectors, large white ones slide forward, undo 4 little scres. Ensure you note which way chip should go in. Pry old chip out with a small screwdriver slowly and gently from each end so as not to bend pins uneccesarily.
    Insert new chip with little half moon at end of chip matching the little circuit/chip liftoff, and gently push in. You may have to slightly bend one side of pins inwards to fit the liftoffs, unless the new chip is on a piggyback board.
    Any easy way to do this is to place one edge of pins on a tabble and gently role away from you the line of pins. Check fit and do again ever so slightly.
    Take you time on chip insertion. Broken pins are hard to fix.
    Use an antistatic strap, as well. Maybe a dollar or 2 at your local Tandy shop.
    Mar 2005
    Rabun Gap, Ga.
    Thanks so much, I will get it in tomorrow as soon as i check Radio Shack for the anti static strap.
    apriliaforum expert FalcoPilot's Avatar
    Jun 2004
    North Georgia, U S of A....
    I did this a couple of weeks ago, Squirrel. A word of advice. (Via Carlos, THANKS!). The screws holding the box together were put in by a gorilla. Instead of buggering up the screw heads, just go ahead and use some vice grips to break them loose. It won't damage the screws so you can reuse them.
    2003 Aprilia Falco SL1000R
    2007 Mazda3 Five Door
    1991 Ford Mustang GT
    1968 Mustang Coupe
    apriliaforum expert falco03's Avatar
    snow free northeast
    maybe you're just a wimp, FP.
    "Buy land. They've stopped making it"...........Mark Twain
    Jun 2004
    Quote Originally Posted by falco03
    Hmmmmm, could be, but this says that I'm still ahead of you!!!
    1968 Mustang Coupe
    apriliaforum expert Wot_bike_isit's Avatar
    Santa Barbara CA USA
    FPs right the hardest part will be opening the box
    "The medium girls over there......It is a disaster!"
    Rossi
    "For me ees niice...no problem!"
    Cappirossi
    apriliaforum expert go_modem_go's Avatar
    Jul 2004
    Yurop
    Quote Originally Posted by FalcoPilot
    Just in case you do f*ck-up the two sealed screws (which I did ):
    They are exactly the same ones which are used in almost all PC's for hard disc / DVD disc drive mounting. Just re-use the fine-thread screws of your old computer
    Mar 2005
    Rabun Gap, Ga.
    Thanks for all the help. Got it out and replaced with no problems, screws were not an issue, chip fit was fine and it even started right up first time. plan on taking it out on Sat. or Sunday to see how everything works on the road.
    apriliaforum expert CarlosT's Avatar
    Oct 2003
    Right Outside Of Philly Yo
    What kinda chip is it again?
    Where da booty at?
    Mar 2005
    Rabun Gap, Ga.
    It was the chip that came with my Falco Fighter cans, no numbers, just said "Falco Fighter" on it.
