Results 1 to 3 of 3
Thread: cilp-ons ?
    Jan 2005
    California, USA
    cilp-ons ?
    Can anyone tell me for sure whether or not the '01 - '03 RSV (Showa) OEM clip-ons will fit and bolt to the underside of the Falco top triple clamp?
    I'm considering a Falco as a track bike and would like the lower bar height.
    Ron6533
    '03 Falco, red:
    Staintunes
    de-restricted
    Factory Pro chip
    fuel press. regulator
    Evoluzione filter
    Penske 8987 shock + ride height
    r. wave rotor w/EBC pads
    Galfer S.S. lines
    Pirelli Diablos
    43T sprocket
    D.I.D. X-ring chain
    Skidmarx belly pan
    Carbon f. fender
    smoke touring screen
    RSV signals
    R & G front frame sliders
    Motovation rear frame sliders
    Motovation fork sliders
    side stand "spacer"
    gel grips
    Quote Originally Posted by Ron6533
    Yes, the top clamp and fork tube assemblies are the same and the Mille Showa clip-ons will bolt on. The Falco cables and hoses may be longer though.
    apriliaforum expert stoneflylama's Avatar
    Oct 2003
    Knoxville, TN
    You may have minor clearance issues with your fairing stay/bracket and your brake/clutch levers.
    I was using clipons from a Ducati 916 on my Falco for the track. The levers would hit bracket at full lock either side. The Mille bars are slightly higher and slightly farther back than the 916 or aftermarket clipons. Should be easier to make work and have better clearance.
    "Guess what? I got a fever, and the only prescription is more cowbell."
