Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Thread: Warning to all metal-tank owners
    apriliaforum Member Aprilia13's Avatar
    Pacific NW
    Exclamation Warning to all metal-tank owners
    Finally tracked down my gas spew problem (not so hard, just needed the time). I still don't quite understand the point of TWO tubes in the tank, but I digress . . .
    Having removed the fuel pump, I discovered that one of my drain tubes HAD come apart, (the end was still attached at the top of the tank), and the other was not far behind.
    Here's what I noticed: The inside of each line was cracked like crazy up at the top end, where they slip over the metal.
    So, here's what I think: maybe just from sitting in the sun during lunch stops or in a parking lot for the better part of a day at various cycle get-togethers or whatever, the top of the tank gets heated enough to cook those lines a little bit, and make them brittle. Even at a track day (some of us haven't sprung for those trendy little square tents yet) your bike is baking more than it is being air-cooled.
    Anyway my advice is, as soon as you get an inkling to change your fuel filter, (or have it changed by your local trustworthy mech), check those lines, or better yet, just replace 'em. An extra few minutes and a couple of bucks is worth it, because I have a sneaky suspicion it isn't asking physics too much to get a steady drip to ignite and burn back into the tank.
    Ride smarter, not harder!
    apriliaforum expert Ally V60's Avatar
    May 2005
    Germany NRW
    Thanks for the info Aprilia13. I'll certainly bear it in mind when I start my winter strip down, as I have one of the classic's with a metal tank
    Ally
    99' RSV "The Bitch" #063
    [B]Carbon fairing and tail! Blue printed Engine, 54mm tb's, twin Carbon Akrapovic race, Aprilia Akrapovic WSBK Chip, Gillies clip on's and rearsets,Ohlins (RT) front and (PRCLS46) rear suspension, Wave disks, Hel brake and clutch lines, Evo clutch cylinder, Barnett clutch, Evo plug leads with Denso Iridium plugs, 16/44 sprockets, EVO Billet velocity stacks, EVO Airbox, LED rear light and indicators,sticker by AF1
    96 RS 125 Extrema Biaggi rep
    apriliaforum expert NorCalRSVR's Avatar
    Fairfield, CA
    Looks like dry rot brought on by "green" fuel. Out here in CA, the reformulated gasoline contained MTBE. It's supposed to make the fuel burn cleaner and produce less smog. It gets into the ground water for more serious and unwanted pollution than the smog it's supposed to stop and it rots out fuel lines in hurry. There have been a ton of car fires out here because of it. We're supposed to be MTBE free by 2006 but who knows what the CARB will come up with next and force down our throats with out proper testing and evaluation first. I don't know what could have caused that kind of dry rot on your tubing....you guys run a high alcohol content during certain times of year in Indiana?....sean
    apriliaforum expert duganc's Avatar
    Oct 2003
    Chester NJ
    Guess what the secret ingredient in VP U4 is....MTBE. The same reason it is used in 'green' fuel is why it is used in race gas - it really boosts oxygen levels.
    "I feel strongly both ways."
    '01 Mille Blue - Mods (a bunch but not enough)
    Former rides:
    '92 VFR750F
    '89 NT650 Hawk GT
    '63 CB77 Super Hawk
    Pacific NW
    Quote Originally Posted by NorCalRSVR
    Some stations here do sell fuels with 10% alcohol (if I remember correctly) and they're usually cheaper, but I don't buy that stuff, ever. But anyway, my lines were only cracked / broken where they attach at the top, at the filler cap, but the bottom halves (which are submersed most of the time) are still soft. So I'm having a hard time thinking my fuel has much to do with it.
    apriliaforum expert Fustern's Avatar
    Jun 2005
    New Hampshire
    Looks like the latex tubing that they use with sling shots..I also used to use alot of it when I was into SCUBA diving. That stuff rots bad just sitting in normal air without any contamination.
    apriliaforum expert LUCKY DAVE's Avatar
    Sep 2005
    Encinitas, ca
    Looks to me like pvc tubing, which isn't suitable material for fuel lines. It hardens with age and oxidation. All old British bikes came with that stuff, and it always turned into iron just before it cracked.
    A finish is a win! Moderation is the key! More wine!
    And never lend a faggot your hat
    Proud Member of Team Punisher and The Texas Mile 200 MPH club
    Motorcycles are not just fun toys. They are a catalyst for the enjoyment of life. - NaimChase
    When you ride a bike that tries to crawl out from underneath you at 150MPH with a slight twist you know you're on the right path. - TRexRacing
    apriliaforum expert Eskimo's Avatar
    Mar 2006
    Danville, PA
    Are people just replacing it with regular old rubber fuel line? looks like 1/4"?
    Rich in PA-
    '04 Tuono Coaching / Street - Traxxion Dynamics, Gabro chipped, Arrow 2-2, 30k+ miles
    R6 Race - The usual stuff and some not-so-usual stuff. CCS #128 Expert
    www.KeystoneRiders.com - Central/NE PA message forum for street/track riders
    EvolveGT coach
    Thanks to my 2016 sponsors! METRIC DEVIL MOTO / PIRELLI TIRE | SCORPION | YOSHIMURA | PIT POSSE | WOODCRAFT | VORTEX | PARTS CLUB | HAZARDOUS RACING
    GET IT!!! http://www.richquinlan.com
    %@*#&! hank's Avatar
    Earth
    Quote Originally Posted by Eskimo
    Instead of replacing the tubes with the Aprilia part that is simply the same material, a good alternative source is needed.... we need the guru's to find a source and perhaps a bulk/group buy is in order...
    Buffalo MN
    I use the blue poly fuel line from parts unlimited on all my off road stuff, wonder if this would be a good replacement??
    If a little is good..... A LOT MUST BE BETTER!!
    RSV MILLIE
    CR250
    KX450F
    RAPTOR 700
    MXZ800
    May 2007
    thanks
    thanks for the suggestion
    Earth
    Quote Originally Posted by GEARHEAD9969
    Anybody know the inside diameter of these hoses?
    Pacific NW
    It's 8.0mm, or 5/16 inch. (that's i.d.)
    My hose (insert juvenile joke here) is from NAPA, and reads: "FUEL LINE 5/16 INCH (8.0mm) SAE 30R7 NOT FOR FUEL INJECTION SYSTEMS MADE IN U.S.A BY GATES" I bought 6 or 8 feet for a buck or two. Anyone replacing these should just make sure the exterior of the line is also suitable for immersion in fuel. I would think the blue line you speak of would qualify.
    Getting close to two years now with no problems since I put these in.
    Earth
    Quote Originally Posted by Aprilia13
    Thanks - I wonder if the change from stock would effect the level of pressure from the fuel pump... Probably not at all or not enough to reauire adjustment of the fuel pressure regulator.
    Jan 2007
    Hammond, Indiana - USA
    Quote Originally Posted by hank
    Hank:
    These are tank cap overflow lines designed to drain water and gas that gets into the cap recess. They don't connect to the fuel system - just drain pipes that run through the tank. No way they can affect fuel pressure - unless they take a crap and drain all the gas on the ground.
    Hoosier, not hoser.
    2016 Tuono 1100 Factory
