Page 1 of 4 123 ... LastLast
Results 1 to 15 of 49
Thread: Fried Toasty Brown Connector
    apriliaforum Junkie loungesurfer's Avatar
    Encinitas, CA
    Unhappy Fried Toasty Brown Connector
    I know there are lots of other postings showing their melted brown connector, but I thought I'd add my own.
    I was reading all the charging/brown connector threads earlier this week and decided I needed to check mine and fix the connector soldering. We'll I'm sure glad I checked while it was in the garage. The whole right side of the connector leading to the rectifier was completely fried! (photos are attached). I'm a little surpised it fried on the side leading to the retifier given they are properly soldered and the other side leading away was not. Guess it doesn't really matter.
    The fix was to replace the connector with the Posi-Lock connectors someone else used. Niffty little connectors! Thanks! All's back in order now.
    Thanks to all who have shared their similar connector stories.
    Denys - aka Loungesurfer
    Denys - aka Loungesurfer - Encinitas, CA
    2001 Falco - Red
    Retired 2004 Futura - Ash Black
    Aug 2005
    so cal
    what year and how many miles are on your Fut?
    apriliaforum expert ib12's Avatar
    Tamworth UK
    Great to see quality parts are used in putting together this bike eh.
    Brian
    [ZZR1400 190bhp, Baglux tank cover, 14.4v charging,ABS,TomTom GPS, double bubble, hugger, crash bungs, heated grips, permanant grin, fluffy dice ]
    apriliaforum newb drakis2004's Avatar
    Sep 2005
    Irvine, California
    Yikes - glad you didn't get stranded. Anyone know where these connectors come from or how to get some? I'd love to set up a test bench and run a batch through a series of controlled tests.
    If you haven't eliminated the brown connector yet, do yourself a favor and replace it by soldering the connections or getting some better connectors. My Aprilia shop (which shall remain nameless, because they usually provide top service) told me to just keep the brown connector clean and tidy, and I'd have no problems. It melted two weeks later.
    WV... Northern Panhandle
    You should be able to get the Posi-Locks at most Autozones and the like. Even one of the Marts(K or Wal) may carry them. Check the sizes and they even have temp ranges on some.
    rdb
    Connecticut
    Soldering only one side of a male/female connection doesn't really accomplish much as they are locked together & both will overheat. As many times as this has been mentioned on this forum I'm surprised that anyone is still riding around with an unsoldered brown connector.
    John B.
    Encinitas, CA
    What Year & Mileage
    Quote Originally Posted by keithroxx
    It is a 2004 with 6,200 miles since I purchased it in March 2005.
    Quote Originally Posted by bikpaintr
    You're correct - I should have replaced it sooner, but delayed until now. Luckily it was parked at home and not stranded somewhere in San Diego County.
    Thanks,
    Denys
    2001 Falco - Red
    apriliaforum Junkie mgtx73's Avatar
    Austin, TX
    Wow, that one looks like mine did. Unfortuneately for me I was left stranded away from home with the misses on the back with a dead battery as I came to a stop sign. Got it fixed at AF1 though.
    Mike
    '01 Futura
    apriliaforum expert Dan's Avatar
    Upstate NY, Orlando, FL
    (Raising hand) For 58k miles.
    If I just gave you mechanical, personal, legal or medical advice, it's up to you to get a proper diagnosis from a qualified expert.
    near Madison, Wi
    Heres a question...
    With all the connector work going (and gone) on, has anyone found their connectors packed full of dielectric grease like mine was?
    My bike is #50 and appearently (sp?) was greased at the factory. Did they not continue the practice during the run?
    I did the wire mod anyway but I'am still on the original connectors, battery, fuses, solenoid, etc. etc.
    "Where it is a duty to worship the Sun, it is pretty sure to be a crime to examine the laws of thermodynamics." J. Morley
    Of all creatures on an incredible, unique, alive and beautiful world, the human is the nearly totally defective element; like the cancer which is basically, out of control, knowing no limits and respecting no boundaries.
    Arlington, Texas
    I wonder...
    I took my brown connector apart and soldered all the terminals soon after the failures started being posted here which was, I think, about 2 years ago. Plus I've been using De-Oxit on those therminals. Then I did the wiring mod 12 months ago. Now I've only got 10k miles on my 2002 and so far no problem. BUT, every time a new failure is posted I wonder if I'm doing the right thing by leaving that brown connector in place. Hmmm...
    Has anyone had a failure that has soldered all the terminals and used an anti-oxident on that connector?
    John
    Connecticut
    Quote Originally Posted by rowdy lee
    I never saw any signs of dielectric grease in the connectors on my 02 & I'm glad of it. Still got my original connectors (both soldered), fuses, solenoid but the battery was replaced once.
    John B.
    near Madison, Wi
    Well...
    IMO, the grease or compound or call it what you will, probly keeps corrosion and oxidation and oil mist and road grunge out of the plug-connectors... any of which would increase resistance... not a good thing certainly, and probly contributors to failure... if not a general "weakness" ... sub-par performance in the system
    But, I'am not an EE and don't give a F about mechaniking or even speculating any more... so, whatever.
    apriliaforum expert CarlosT's Avatar
    Oct 2003
    Right Outside Of Philly Yo
    File your complaint here...as should all you f_ckers with toasted or grilled cheese brown plugs
    http://www-odi.nhtsa.dot.gov/ivoq/
    Where da booty at?
    Connecticut
    If applied properly dielectric can be good for waterproofing a connection. Unfortunately it is often smeared all over the electrical connections & since it is non conductive it can cause more problems then it will prevent. In a situation like the brown connector which does seem to get hot I'd be afraid of the grease melting & seeping into the male/female connections.
    John B.
