My figures were
Prior:
volts at idle 13.75 volts at idles with lights on 13.84
Volts at 4K revs 13.40 volts at 4K with lights on 12.95
Before I did the mod I also checked the voltage from the reg/rec b!!!!!
efore it goes to the battery.It was 14.15 at idle and 14.20 with the lights on.This clearly shows that the wiring is at fault and not the reg/rec.
I did the mod by chopping the brown connector out and soldering the 3 wires together.
I ran a 5amp length of cable for each of the 4 connectors coming out of the reg/rec.
2 of the wires i soldered onto the 2 red/black wires and ran both directly up to the rear of the 30amp underseat fuse where i soldered them to the red/black wire.
The other 2 5amp wires I soldered onto the remaining 2 blue wires from the reg/rec connector.I soldered these directly to the battery negative lead.
My voltages after the mod are excellent:
14.30 at idle no lights 14.20 at idle lights on
14.10 at 4K 13.95 at 4K with lights on
My thoughs are that it is both the positive and negative parts of the circuit that are loosing voltage;it is well worth adding the negative wires into the equation.The postive wires will make things better.The negatives better still!
Bailey.
