Results 1 to 7 of 7
Thread: Gearing Recommendations?
    AlphaAuriga
    Guest
    I'm picking up my Mille R in the next few days and have a couple of questions.
    I'd like to order a 520 chain and "gears", But I'd like some suggestions from racers what is a good countershaft sprocket size to go with and a rear sprocket size or sizes.
    I know it depends on the track size. We race mostly on shorter tracks. Not alot of long straight type tracks. I think the longest one is about 1/2 mile long. But thats one track out of 5.
    Just looking for some good starting points!
    TIA
    Yammyfan
    Guest
    [off topic] Howdy Alpha,
    You going to race the mille? the R6 going? [/off topic]
    (cant offer you any on the Q )
    AlphaAuriga
    Guest
    Dang, Busted!
    Well, I actually sold the R6 two races into last race season. I had actually planned not to race it at all because I purchased TZ250 to race. But 1 freakin' month before the first race, I had a crank seizure. Missed the first two races on it trying to get it put together.
    Did well on the TZ, Consistent top 3 finisher and even a win on the fastest track we race on. But the TZ is too much work. I can't just ride it and put it in the garage. Every outing meant the heads and cylinders would have to come off for inspection. Every 300 miles, a new top end, 1200 miles rebuild the crank. Pretty pricey to keep running too. My preseason purchase of "consumables" and a crank rebuild put my before season expense at about 1500 dollars.
    Don't tell the guys on the R6 board
    Yammyfan
    Guest
    <blockquote><strong><em>Quote:</em></strong><hr>Don't tell the guys on the R6 board[/quote]
    Who, me? I haven't had a 6 for near a year also
    I saw you had an expert win this season...well done
    The Mile should be a hoot!
    micah apriliaforum com
    Guest
    I like 16:44 for faster roads and tracks and 15:44 for shorter stuff.
    mouimet
    Guest
    What is the stock gearing for a 2000.5 Mille?
    harring10
    Guest
    Gearing
    I run the 16/44 combo and absolutely agree that it's the way to go for street riding/canyon carving etc.
    I've run pretty much the whole gambit of bolt on performance mods and think the 16/44 is probably the best return on the dollar.
    So far completed is:
    Harris 2-2 race system
    Evoluzione race air box and filter
    Evoluzione ignition amplifier
    Hi Po plugs/plug wires
    Evoluzione custom Hi Po chip
    54mm throttle bodies and accompanying SP stacks
    16/44 gears (525 D.I.D./AFAM sprockets)
    Arrow rear sets
    M-1's and HH pads
  1. 2006 Tuono Engine / Gearing
    By Phil3 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 09-18-2005, 05:03 PM
  2. a gearing or FI issue
    By lepeeps in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 07-19-2005, 01:06 PM
  3. Gearing - street use?
    By Key Walshe in forum RS250
    Last Post: 09-11-2004, 02:32 PM
  4. What RPM can you get to in 6th with different gearing?
    Last Post: 08-04-2004, 01:26 AM
  5. gearing change
    By stuboy in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 05-09-2004, 05:31 AM
