Results 1 to 4 of 4
Thread: RS250 99' RPM indicator problem
    Jul 2005
    Alajuela , Costa Rica
    Hi. I 'm having some problems with the tachometer of my RS250. From time to time , it show wrong rmp. For example , with the bike at idle it shows 6000 RPM. I have to take out the 20A fuse in order to "reset" it , but i loss the partial odometer and other info (max speed , avg speed). What can be the problem? Anyone know exactly how the RPM indicator of this bike works? Is there anyway to reset this indicator without having to remove the fuse? Thanks!
    Alejandro Arce
    aarcep@gmail.com
    apriliaforum Member Twodogs's Avatar
    NSW Australia
    The tacho tells lies if the battery is going flat or is near flat. That could be the problem
    Jul 2005
    I tought that , so i replace the battery (Yuasa YB4L-B). But the problem remains. Any more toughts? Thanks!
    Jul 2005
    singapore
    Question
    i also encountered a rpm meter prob recently.... the meter normally should show idling at around 1.3 to 1.5 but now its lower then 1 and its not the setting prob... any ideal how to rectify it? mine is 98+ model
