Results 1 to 6 of 6
Thread: Please help.
    apriliaforum expert RSVMIllenian's Avatar
    Chicago, IL
    Please help.
    Yesterday I removed my wheels and my sprocket in order to check the bolts if they gor loose. However, when I took the sprocket of the wheel I didn't know what bolts to check.
    1. The bolts that or on the sprocket assembly from the back (side that goees into the rubber bushings)
    2. The Allan bolts between the rubber bushings on the wheel itself.
    I tried searching but could not find detail explanation. Thanks.
    Dan
    apriliaforum expert orangeokie's Avatar
    Jan 2004
    Oklahoma
    Torque Chart
    According to this thread it is both the sprocket holder bolts and the allen head bolts between the cush drive that loosened. aprilia powdercoated over these bolts on my OEM wheels, but when I had them re-powder coated, I took everything apart, so I will probably check these periodically to make sure they are torqued properly.
    Chicago, IL
    Mine are also powdercoated over the bolts. I will have to check if they are ok.
    apriliaforum expert Carbon Can Kat's Avatar
    Riverdale, GA
    Go to cplus' site and download THIS PDF. The parts you are concerned with are #9,10 and 20 on cell 35. It shows up as page 49 in my acrobat reader.
    Jan 2004
    Oklahoma
    This may be the same thing. Didn't know you were looking for a parts diagram.
    Chicago, IL
    Thanks everyone
