Results 1 to 4 of 4
Thread: What is the spark plug wrench?
    flamingmenudo
    Guest
    I am trying to check my spark plug for deposits and to clean it off if necessary. What is the spark plug wrench that the Scarabeo manual is referring to? Is it that brassy tool under the seat?
    jj008
    Guest
    yep. Stick it over the spark plug and use the screwdriver to twist it out.
    flamingmenudo
    Guest
    phidauex
    Guest
    just for reference
    Just for your reference, the ditech sparkplugs are 16mm. I use a 16mm deep impact socket connected to a long handled torque wrench for spark plugs, makes sure I can get the right torque easily as well. If you find you are removing your spark plug regularly, you can get a basic set of metric 'deep' sockets and a basic torque wrench for pretty cheap, and it makes the process much easier than the goofy little wrench that aprilia provides. I can't tell you how many times I've busted my knuckles on something up in there trying to get the plug out with the aprilia tool before I got a set of actual sockets and wrenches.
    Peace,
    sam
  1. Wire mod instructions for Dummies, Like ME!
    By Firebolter in forum SL1000 Falco Forum (all years)
    Last Post: 04-26-2013, 11:08 PM
  2. Oil, spark plug, moisture & cooling
    By StockMan in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 05-12-2009, 02:40 AM
  3. Ditech spark plug problem - PartOne
    By explosive in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-09-2007, 04:03 AM
  4. (SR 50 R 2005) Need help on spark plug and carb.
    By leobusti in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 03-12-2007, 07:34 AM
  5. Spark Plug type for 2006 SR50 Ditech
    By Apriliable in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 08-28-2005, 04:03 AM
