Results 1 to 10 of 10
Thread: Experienced help required pls
    My carburetor is leaking fuel. I have narrowed it down to the two areas shown in the picture. The nut that covers the black cap over the fuel filter appears to be on tight enough. I've had the carb off and cleaned the inside areas. Any ideas on what to do?
    (its NOT leaking from the hole in the second image)
    Mar 2004
    stes mum ville
    try puttin some sort of thread tape or sealent on them
    apriliaforum Member laverdamancouk's Avatar
    Dec 2003
    notts
    bets to take the base off and look at the jets and look in the float bowl for shit of any kind...sounds as though it coming from the over flow .....also be careful with the floats ...and check the float height of them...
    apriliaforum expert James_3's Avatar
    Dec 2004
    Grimsby, UK
    from the pics that looks nothing like the carb overflow!
    maybe if needs a new rubber seal or some sealant
    Parts For Sale:
    Front Fairing good condition needs spraying £pm
    Handlebars and speedo cable + controls etc £20
    43T Rear Sprocket
    Quote Originally Posted by James_3
    what kind of sealant would you use? is that the type you'd use in a bathroom?
    Quote Originally Posted by laverdamancouk
    i did that- the only crap i found was where the fuel filter is.
    apriliaforum expert kaplano1's Avatar
    Sydney, Australia
    Are you sure the carb is not leaking from the small black overflow tube?
    Mine occassionally leaks fuel when I turn the fuel tap ON (from this tube).
    I just tap the carb with a screw driver to dislodge any dirt, etc and it seems to be ok.
    People recommended to me that I take apart the carb and clean it with carb cleaner and check the float was not getting stuck.
    i dismantled the carb n cleaned it. The fuel leak is definately from the main fuel line. I'm considering cutting an inch off the cable (maybe its split???) But its definatly leaking from the boxed areas.
    where would you buy a new black cap?
    maybe its related : the bike has recently started to just bog down and die, requiring the choke to be applied to get the engine started again. Is the carb supplying too much fuel, too little fuel? What does the black knob do? What does the silver screw do? ie which one is the mixer?
    Dec 2004
    Grimsby, UK
    black screw is the idle
    if u need to put the choke on that means that there is not enough fuel geeting in.. which makes sense because half of it is leaking out!
    Parts For Sale:
    43T Rear Sprocket
    Post Whore Craig's Avatar
    Guisborough
    I'd give your float bowl a good clean you could have a sticky float needle and the fuels running out of the over flow. Failing that check the gaskets are sealing right.
    VAG Cars - www.vagcars.co.uk - North East VAG Owners Club
