Results 1 to 2 of 2
Thread: micah do you have...
    wallburg
    Guest
    I need to get a hold of new cylinder bolts(the 4 bolts the cylinder ride on), cylinder head nuts(4 go on the end of the cylinder bolts holds your head on), As well as a new tp 75cc piston kit and the apropriate gasket kit.
    is there a good way to remove rust and corrosion from your cooling system? how about flushing it with "lime away"
    wallburg
    micah apriliaforum com
    Guest
    Just run the garden hose through the system. I have all the TP stuff you need but you will need to get the studs from your Aprilia dealer.
  1. Replies: 0
    Last Post: 03-23-2004, 04:00 PM
  2. Replies: 7
    Last Post: 03-11-2004, 09:20 AM
  3. ECU Questions again ... Ping Micah
    By Felix Da Cat in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 01-01-2004, 01:31 PM
  4. Micah
    By Steve / AF1 Racing in forum RS50 Technical
    Last Post: 12-12-2003, 11:46 AM
