Is there any advantage of fitting a blanking plate with a cut down valve instead of working powervalve or is it just people derestricting bikes cheap?
Kickstart Motorcycles | Peter Knight | jap4performance | URL cloaking
01 RS125, JL SS&CF single, 34mm carb, PiperX panel filter, carbon reeds,cdi mod,SS braided hoses, ebc HH pads, 16/39 gearing
surley it would lagg in the midd range, where its designed to have a fully closed port...
ask johnny, he's done it.. im sceptical myself...
Jim lomas SS system, 34mm Carb, V Force 3 reeds, HPI Racing cdi, Mitaka Barrel and piston kit.Powder coated wheels, custom paint nose cone, Skidmarks purple screen & headlight cover, Goodridge braided hoses and 2001 calipers, Gold fren HH pads, SSS gold chain, Renthal rear 39 sprocket, Carbon fibre clock surround, yoke cover, heel plates and Chain Guard, 99 front mudguard, new side panels, rear seat unit, nose cone and tank cover. recovered riders seat.
I also did it, basically you will gain no more power at all, you will lose all your bottom and mid range power but when you hit 8k revs it takes off like a twat! My advice would be to leave the pv the way it is, with a blanking plate it is much harder to use in town riding and what not, plus you have to slip the clutch a lot more than normal!
Jonny only did it because his blade broke, i will say though it does nothing till 8 then goes like hell, but i mean it does nothing before 8.
VAG Cars - www.vagcars.co.uk - North East VAG Owners Club
ive got a blanking plate on mine at the mo, and when it hits 8k, it scares the shite outta me, just have to hold onto the bike, its crazy. luv it
i wouldnt say goes like crazy, afterall its only a 30ish bhp bike, if your riding properly it should be at them rpm's all the time and not drop down below and out the power really.
useful if its a racebike because its less weight to carry.
1992 Yamaha TZR250 3XV
2002 Suzuki DRZ400
2000 Cagiva Mito Evo 2
2000 Cagiva Roadster
Parts currently in stock for RS125, Mito, RG125, CBR125, VFR400
Need RS125 parts? Drop me a email sales@crotchrocketspares.com
Aprilia Motorcycle Breakers 125cc Spares
Piaggio Scooters
My Bikepics
to try it unplug the power to the solenoid and then using a cable tie hold the solenoid in with the cable tie so the PV blade is open all the time.
Pulling off is very hard and forget doing hill starts bike is very groogy till you hit 8000rpm and the front wheel will feel like it gonna lift up![]()
If your pv is working dont bother.
