Results 1 to 8 of 8
Thread: Fuel Quick Disconnect at Cost - I bought bulk
    Jul 2016
    Holly Springs, NC
    1/4" barbed coupler bodies - Colder part# LCD17004 - $18 - 2 needed for full set.
    1/4 NPT male fuel pump fitting - Colder part# LCD24004. $11
    3/8" barbed unvalved return line male fitting - Colder part# LC22006 $5
    I have 5 full sets or i can set up individual.
    It's a Colder dealer in Raleigh NC -
    If we can get 3 or more people, I can get shipped ASAP.
    Scottsdale, AZ
    LP,
    Regarding the 3/8" un-valved male fitting, the original plastic coupler bodies had protected latch levers to prevent the coupler from accidentally coming unlatched. The new metal bodies don't. So I decided to install a valved 3/8" male instead. With the valved male, should the return line coupler become detached, the fuel pressure would go high enough to cause very rough running and probably engine stall with little chance of fuel leakage. But with the un-valved male, if it became detached, the engine would continue to run normally while a)the fuel tank contents were pumped out on top of the engine and all over your pants, or b)the engine caught fire and burned the bike to the ground. Not saying my way was better or smarter, just providing food for thought.
    Stu
    Jul 2016
    Holly Springs, NC
    As always thank you! My Capo been laid up for over a year and the fuel pump issue has awoken! One of my quick disconnects seams broken as it popped out the plastic and spring upon disconnect.
    Can you post a part number?
    You make me think of just adding a pet-cock to cut off fuel when I need to disconnect.
    This link - http://www.caporider.com/FuelLine.shtml
    Scottsdale, AZ
    Quote Originally Posted by TerrenceLP View Post
    If you mean that the guts popped out of the coupler, the only fix for that is a new coupler, and it seems you've posted the part number yourself.
    On the issue of the valved 3/8" male fitting, I don't think you understand why installing a petcock in that hose would not save your a$$ from a fire. But a check valve in that male fitting would - whether it was you who decided to open it, or if it came open accidentally. The link you posted to Caporider.com is me showing the parts and technique I used back in 2004. Unfortunately, I hadn't decided at that point to use the valved fitting and didn't update that post. Sorry for the inconvenience. The Colder # for the 3/8 w/check valve is LCD22006. http://tinyurl.com/y8juycdw
    Colder LCD22006 Chrome Plated Brass Tube Fitting, Insert, Shutoff, In-Line, 1/4 Insert x 3/8 Barb
    Jun 2018
    costa mesa CA
    I was thinking that exact same thing.
    apriliaforum Member MAD G's Avatar
    Jul 2013
    Germany (Giessen)
    Maybe read this: https://www.motrag.com/projects/
    I would recommend these, because no more O-Ring which easily can be damaged.
    Best Regards
    Manuel
    apriliaforum Member sparco's Avatar
    May 2012
    Podgorica,Montenegro
    i went the lazy way, straight to innerbags seller from germany on ebay and bought 2 x shchnellkupplung for bmw 1200 for 80 euro fixed it and forgot about it
    same as Manuel said, no o ring
    apriliaforum Member laszlo__'s Avatar
    Sep 2005
    Szekesfehervar; HUNGARY
    Quote Originally Posted by MAD G View Post
    Best Regards
    Manuel
    Nice stuff Manuel.
    60 V2 ..... best ever.....
    2013- APRILIA ETV1000
    2005: APRILIA RST1000
    2002-2005: BMW F650
  1. Fuel quick Disconnect Elbow
    By stupeo in forum RST1000 Futura (all years)
    Last Post: 08-28-2013, 07:19 PM
  2. Fuel Quick Disconnect O-rings ?
    By aoro in forum ETV1000 CapoNord (2001-2007)
    Last Post: 04-16-2013, 03:37 AM
  3. Fuel quick disconnect
    By srastoder in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 02-23-2012, 11:04 AM
  4. Fuel quick disconnect (QD)
    By transparent_opa in forum SL1000 Falco Forum (all years)
    Last Post: 12-10-2009, 04:30 PM
  5. metal fuel quick disconnect mounting
    By 01Futuraman in forum RST1000 Futura (all years)
    Last Post: 09-25-2008, 05:31 PM
