Results 1 to 13 of 13
Thread: Couple o' Q's - chain link removal + tyre mixing
    Mar 2004
    Glasgow
    Got my new chain and sprockets of Craigy boy but am having difficulty getting the peaned soft link out of my old chain. Tried sawing the head off and knocking it through with a nail & hammer but it won't budge. Anyone got any ideas on how to get the bugger out?
    Oh, and whilst I'm taking the back wheel off I figure I might as well get my back tyre replaced (it's square ). It has a set of Dunlop 204's on atm but the front has plenty of life left - bearing in mind funds are a bit tight should I;
    a) match my front D204 with a rear D207/8
    b) get another D204 for the rear
    c) it'd be best to get a front & rear 207/8
    Thanks as always!
    May 2004
    if you have a new chain,and no chain breaker,cut the old one off.
    im assuming the new one is a split link then?
    Post Whore Craig's Avatar
    Guisborough
    Best way is to prise it off, but if the chains knackered just cut it. The reaosn i got those IRIS chains is because there heavy duty and have BOTH rivert and split links, makes life so much easier.
    I've personally just got rid of a new 96 front on the RVF because i was getting 090's fitted so went for the front and rear option. The sportsmax's are good i have nothing to complain about they got hot and soft after awhile, held there profile (unlike some BT92's i ran the RVF on) and lasted awhile too.
    VAG Cars - www.vagcars.co.uk - North East VAG Owners Club
    Mar 2004
    Glasgow
    Cool, what would I use to cut a chain that thick tho?
    Yeah Dave, it's the Iris as Craig said which comes with the option of split and rivert.
    Which link type would be best to use in your opinion Craig?
    And which of the tyre options in light of the fact I spent most of my money on your chain Would mixing a 204 and a 207/8 be an absolute no-no, or would it be 95% as good?
    May 2004
    ive got the same chain mate,use the split link,then you can take the chain off for cleaning.
    cut off the old one with a hacksaw mate.
    Mar 2004
    Glasgow
    Ah christ, that'll take me all night Dave!
    See you in 3 hours :p
    May 2004
    nah 5 minutes,or use a dremel or similar,they are easy to cut
    Mar 2004
    Glasgow
    Yep, you were right Dave, only took 5 minutes.
    Now I won't be able to wait for a new tyre to get fitted, cos no doubt that'll take a few days as my local prila dealers don't stock tyres for the RS
    I'm thinking I could order tyres off the net and get them fitted at the dealer - how much does fitting usually cost per wheel if you take them off?
    apriliaforum expert mightymeaty83's Avatar
    Jun 2004
    nottingham
    sorry for hi jackin the thread goof....
    Craig how much are those IRIS chains???
    might get one to go with those new sprokets
    kris_kerry@hotmail.com.
    add me if u want....
    full power, induction kit,34mm carb,160 jet, renthal 40t rear 16t front, IRIS H/D chain, sinterd pads,polished caliper, droppped forks 20mm,carbon mudguard, mini arrow indicators,L.E.D rear lamp, angel eye conversion and HID Headlight!
    Guisborough
    There £45.00 i have one left, have a few more on order. You would need to make postage £5.95 (you will see how heavy the package is) as it costs £10.00 to send but i only charge £5.95. Most likely will use a courier after i found out its costing just as much to send first class than it is a courier.
    Jun 2004
    nottingham
    ok... sort one out for me
    ive already sent that postal order off for the other stuff...
    so if u want to hang on to it i will get another p[ostal order for the chain
    and u can send the lot together...
    that make sence?
    Mar 2004
    Glasgow
    Like I said in email Craig, it's deffo worth getting in touch with a courier - they'll do you a set price regardless of weight and you can just take the small stuff down to the PO.
    Mar 2004
    Glasgow
    Edit: never mind, found the info in the workshop manual.
    motorbike-tyres.com was the cheapest - I just order at 4.30 and they said I'll still get them tomorrow
