Results 1 to 6 of 6
Thread: Sportcity 250 ground wire locations
    apriliaforum prov-nov Finprilia's Avatar
    Jan 2017
    Finland
    Sportcity 250 ground wire points to the frame
    Hey,
    can anyone tell where are the ground wire connections to the frame?
    I have weird charging problem and I am waiting for a new voltage regulator and thought it was a good idea to check all the ground wires but can not locate them.
    Jan 2017
    Finland
    Help please anyone ?!
    NC
    I don't own a Sportcity but I would download a manual and find what they say.
    Jan 2017
    Finland
    No help from the manual, I reckon it so basic stuff that they have not even bothered to put it there.
    I have found two ground points on the start motor mounting but would like find the chassis ground points.
    Tried to follow the ground cable from the battery but it ends up to big main harness and I do not wanna tier it down.
    My voltage regulator fail and I have read from many places that bad ground/earth may have caused it, that`s why I am trying find those points.
    Do not wanna blow up new voltage regulator right away.
    Jan 2017
    Finland
    My friend who works as a electrician told me to put extra ground/earth wire from the chassis to the battery negative.
    So, problem solved.
    Clearwater, Fl
    Quote Originally Posted by Finprilia View Post
    So, problem solved.
    Been kind of busy with other stuff however that is sometimes the most simple option. Somehow I have it in mind that the factory ground from the battery is near the voltage regulator in the belly pan area.
  1. Wiring diagram with good resolution Sportcity 250?
    By Finprilia in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 06-28-2018, 01:16 AM
  2. Ground strap/wire - location
    By Jeff U in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 08-06-2014, 11:31 PM
  3. Ground Wire - Proper location??
    By JedB in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-14-2007, 07:20 PM
  4. Ground Wire - Proper location
    Last Post: 09-12-2007, 06:11 PM
  5. How do I get a good ground wiring?
    By FrancoisK in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-01-2003, 02:02 AM
