Results 1 to 7 of 7
Thread: Valve cover M6 special screws: use once or re-usable?
    Southampton
    Just checking up on whether my local (non-Aprilia) bike shop is correct: can the 5 screws that hold down the valve cover be re-used? I was advised to get replacements but at 13.08 a pop + delivery (and that's if they have them in stock) I thought it best to check first!
    apriliaforum expert Unique's Avatar
    Nov 2010
    Kolding, Denmark
    I reused mine. Twice
    Capo 2004 Flame red.
    MosFet RR, Eastern Beaver harnes, Metal fuel couplings, HyperPro rear spring, Ricor intiminators, Hepco Becker alu cases, GPS controlled ProOiler chain lube system, iridium sparkplugs, Garmin 660 SatNav, Aprilia heated grips, Aprilia chrash bars, Wilks sump guard, Brembo 4 pot brake mod, coils, screen mod, Aprilia hazard light, angle air valves, K&N airfilter, Catfish/Grant mapping, fixed internal side cases, Bagster tankcover and bag, Factoy Racing slave cluch.
    Yamaha XT 550 1983.
    Honda CX 500 1978. In bits and pieces.
    Honda NTV 650, 1994 SOLD
    apriliaforum Member skvrnsk's Avatar
    May 2016
    Same here. I was removing my covers three or four times already. As long as the socket is in good shape I don't mind reusing it.
    Southampton
    Thanks chaps - saved a bob or two
    Jun 2018
    teesdale
    the shop are talking about the head bolts that hold the cylinder head to the barrel and crankcases...
    Southampton
    Really? See item 1 on this parts list.
Name:	Screen Shot 2018-07-04 at 20.32.52.jpg
    Jun 2018
    teesdale
    No.1 bolts are the valve or CAM cover retaining bolts....if you bring up the crankcases 2 diagram, item 1 is the bolts that are often replaced once disturbed as they are sometimes stretch bolts and should not be reused.....the cam cover bolts you are talking about are fine and can be reused, just make sure the threads are clean before retorquing them down.
  1. 2012 Oil Leak Advice - Stator Cover or Valve Cover?
    By Farad in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 12-23-2014, 10:26 PM
  2. valve cover gasket re-use
    By TuonoFactory1 in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 03-27-2013, 02:37 PM
  3. Oil under p/valve cover
    By oldgit in forum RS250
    Last Post: 07-26-2004, 07:30 AM
  4. Power Valve Cover ?
    By IanRS in forum RS250
    Last Post: 05-10-2004, 11:33 AM
  5. using RSV or SL master cylinders
    By JoksaR6 in forum RST1000 Futura (all years)
    Last Post: 06-18-2003, 05:45 AM
