Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: What I've done to my Capo for now and what to do next?
    May 2010
    malaysia
    did you use the original sensors?
    how did you connect the wiring?
    is the speedo/tacho/fuel/temperature accurate?
    May 2010
    malaysia
    found some info from the aprilia caponord etv1000 manual downloaded from caporider (I think)
Name:	Fuel Tank Range.jpg
ID:	360347Click image for larger version.
Name:	Air Temp Resist.jpg
ID:	360348Click image for larger version.
Name:	Air Temp Sensor.jpg
ID:	360349Click image for larger version.
Name:	Coolant Temp Range.jpg
ID:	360350Click image for larger version.
Name:	Coolant Temp Resist.jpg
    apriliaforum prov-nov darota's Avatar
    Jul 2011
    Germany
    Okay, here is what I did.
    But be aware, Im no mechanic or electronics technician, Im a simple nine-to-fiver, so no garantee for anything !!!!
    First of all I have to say I made my own loom as I didnt want to cut the original one.
    Aprilia uses multilock 40 plug, Ive got them from TE Connectivity and crimped it,
    In an attachment there are the connections, hope it helps. Its (of course) in German, but google can translate the colors :-)
    You will need an IVR 2 to get ABS and sidestand signal from - to + (or other way round, dont remember exactly).
    Original Speed sensor works well, Tacho is as accurate as gps( way better than original), Fuel gauge works by far better than at original speedometer.
    I didnt get the original Water Temp sensor to work. I bought a temp sensor from acewell and now have OIL-Temp, i renounced water temp.
    You might buy a second temp sensor for water, the dash can handle up to two temp sensors.
    Outside temp is lost, I have to look to the sky :-)
    EFI and of course diag is lost, but Ive Bluetooth obd with android obd app to read out fault durig a ride and tuneecu at home, so no need for that.
    I bought an acewell because it can handle with the original speed sensor, no need for another one or reed sensor and for
    the very good fuel gauge, also with original sensor. And you have a really good working gear display and voltmeter.
    If there are further question, just ask, Ill have a look in this thread.
    And by the way, KarlB fixed my broken dash, but I wont go back.
    Attached Files Attached Files
    May 2010
    malaysia
    wow
    well done
    will digest slowly
    apriliaforum expert Nito's Avatar
    Apr 2013
    Canterbury, Kent
    That’s a really neat job you’ve done, looks great, thanks for sharing all that info.
    cheers
    Nito
    2018 Ducati Diavel Diesel "Nel mezzo del cammin de nostra vita"
    2008 Caponord ETV 1000 ABS- "Il Capo"
    2002 Tuono 1000 RSV-R Limited Nr.035- "Hyperthrust Cleared and Counting..."
    1993 Ninja ZXR750R "NinjaR!!"
    1992 Ducati 907IE "Il nostro passato ha un grande futuro"
    1986 Katana GSX750SE "The unbelievable Pop Kat"
    apriliaforum expert ravenranger's Avatar
    May 2012
    AZ
    Nice
    2006 Caponord 1989 NX250
    IBA#22798 is now #580 AMA#601202
    May 2010
    malaysia
    Quote Originally Posted by darota View Post
    OK, several questions (forgive my ignorance)
    1) Whats the IVR 2?
    2)Whats the Bluetooth OBD and Android OBD? It will be great to read the fault codes if they happen to show.
    3) Gear display for all position - 1,N,2,3,4,5,6? or for neutral only?
    Jul 2011
    Germany
    Quote Originally Posted by tango View Post
    1) Whats the IVR 2?
    1. http://www.acewell.de/acewell/zubeho...ell-ace-ivr-02
    2. same configuration as for tuneecu. Bluetooth obd like this https://www.amazon.co.uk/Engine-Mana...ooth+obd+small and android app torque. Can read and erase fault codes.
    3. 1,n,2,3,4,5,6
    May 2010
    malaysia
    Great
    Will check out the OBD
  1. Oh Deary Me.....Look What They've Done To My Song Ma.......
    By BrisbaNord in forum 2014-2017 Caponord 1200
    Last Post: 04-03-2017, 10:21 AM
  2. What was the best mod you've done to your PRESENT bike and why
    By potere in forum General Motorcycle Talk
    Last Post: 06-23-2012, 12:28 PM
  3. What's the longest trip you've done on your Capo?
    By Zach in forum ETV1000 CapoNord (2001-2007)
    Last Post: 10-28-2009, 10:44 PM
  4. Look what they've done to the sexy Sport City
    By Buckeroo Bob in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 01-14-2008, 02:31 PM
  5. Thinking of Swapping my Capo for a Futura
    By sven in forum RST1000 Futura (all years)
    Last Post: 01-25-2004, 05:17 AM
