Results 1 to 5 of 5
Thread: 2007 mojito front brake question
    apriliaforum expert DeBenGuzzi's Avatar
    Oct 2006
    Minneapolis
    I got a 2007 mojito, 20k on the clock, bought it from a sort of friend well the front brake caliper locked up and was leaking a little too. I took it apart broke free the stuck piston, cleaned it up and now it wonít pump up at all and Iím stumped. Not a lot of options for direct replacement front caliper is there a list of of scoots that use the same caliper or perhaps a replace the whole thing with something better?
    Life's too short to ride, drink, or smoke crap.
    Rides-
    00' Guzzi V11 Sport custom, (sold)
    07.5 Aprilia RSVR trick, (totaled)
    98 Ducati ST2 (SOLD)
    09 DD750 nicely equipped.
    Jun 2013
    croatia
    buy a repair kit and repšlace the membranes inside
    alternative is to replace the whole caliper if its in bad shape
    NC
    Did you bled the air when you put the system back together?
    ontario
    best to rebuild the master and replace the seals in the slave. then start over with dot5.1 fluid because it is high quality. not the dot 5.0
    polish the piston and piston liner in the slave too. after all that you will be so happy that a polish and dot 5.1 will be your first choice. take a look at the pads/rotor/hose while your there.
    Oct 2006
    Minneapolis
    I took it apart and polished everything up, ordering new pads but one side was sticking and I can’t figure out why it was leaking either. where can one obtain new seals for this thing? Ill have to get a vacuum bleeder for it, normal bleeding wasn’t working great, I was using DOT 4, go with 5.1? Also last question, which way/how do I put that spring back in? Might sound like a stupid question but it popped out when I took it apart and it doesn’t have a obvious orientation
    Rides-
  1. Front Brake Question
    By NorCalRSV in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-24-2009, 11:02 PM
  2. Front Brake question?
    By Hangover in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 02-11-2009, 11:13 PM
  3. Front Brake questions
    By FalcoLion in forum SL1000 Falco Forum (all years)
    Last Post: 05-23-2008, 11:52 AM
  4. Front brake question - suggestions please
    By rnh in forum SL1000 Falco Forum (all years)
    Last Post: 04-04-2005, 02:31 AM
  5. More front brake questions
    By sundevil in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-19-2003, 10:29 AM
