Results 1 to 4 of 4
Thread: Sportcity 300 Red warning light
    May 2018
    Chelmsford, UK
    The warning light has started to come on as the engine reaches normal temperature. The light then stays on. Have tried changing the oil pressure switch. Any help much appreciated.
    help please
    Jun 2013
    croatia
    remove the battery for 30 minutes then connect it together and see if it happens
    there might be a error stored in the memory, if it happens again bring it to the dealer so he can read it out.
    if you see the oil pressure light dont drive it and bring it to a shop-
    Jun 2016
    Florida
    is there enough oil in it?
    May 2018
    Chelmsford, UK
    Oil ok , oil pressure switch changed. Have tried disconnecting the battery for 30 minutes, still the same problem.
  1. rs50 2006 model red warning light staying on
    By barnet123 in forum RS50 Technical
    Last Post: 07-01-2011, 05:11 PM
  2. Please help...red warning light went on
    By vitology10 in forum 2008-2014 Mana 850 and Mana 850 GT-ABS
    Last Post: 08-14-2010, 08:13 PM
  3. Problem:: Red warning Light and Temperature
    By nila in forum 2009 RS125-USA
    Last Post: 06-14-2010, 11:39 PM
  4. Red warning light & EFI code will not go off?
    By Christine in forum 2009 RS125-USA
    Last Post: 04-03-2010, 06:40 PM
  5. temp said 135c and red warning light and EFI came on--false reading?? but why?
    By yobbo in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 02-12-2005, 08:29 AM
