Results 1 to 3 of 3
Thread: What should a SC 250 battery gauge read?
    Oct 2005
    Cleveland, OH
    I dug my 2009 SportCity out of winter storage and she fired right up on first touch of the starter button, just like she does every Spring after a winter on a battery tender. Love that bike!
    It set me to thinking of what should the battery gauge on the dash read when you switch the key on before starting the bike? This bike turns on the headlight with the key in the 'on' position, which I wonder if it will lower the voltage reading. I have read that a good battery should read 12.6 - 12.8V fully charged. My second hand scooter with an unknown battery history has never read that high on the dash gauge with the motor off.
    Sep 2009
    I think you probably won't see anything that high, with the engine off you have load from the lights, ignition, injection etc. on the battery. You probably need to measure on a stand alone battery to see that high numbers.
    Clearwater, Fl
    Measure it with a volt meter at the battery terminals or at the accessory socket in the glove box with the key in the off position.
    If you do not have a volt meter you can subscribe to Harbor Freights email adverts and should in short time get a coupon for a free meter with a purchase. Buy something cheap like spare batteries or a $1 item that you normally would buy anyway. My daughters go through enough sanding sponges and disposable paint brushes that I make sure to take advantage of one of the free coupons when replacing those consumables.
  1. SC 250 gas gauge stuck on full
    By jkdrummer in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 05-30-2012, 02:32 AM
  2. what should my temprature gauge sit at on tick over on my sr 50 di tech
    By gjseb79 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 02-02-2011, 08:34 PM
  3. What gears should I install? Malossi or Pollini. Read threads but hard to understand
    By krisnet in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 12-31-2007, 02:43 AM
  4. What Should A Compression Test Read?
    By stoner in forum RS125 Euro-archive
    Last Post: 07-27-2007, 10:50 AM
  5. battery voltage: what should a new battery charge to?
    By peglegpig in forum General Motorcycle Talk
    Last Post: 05-24-2006, 09:20 PM
