Results 1 to 6 of 6
Thread: Clutch lever adjuster screw pushrod
    Jan 2018
    London
    Afternoon...
    So... I am still fighting with the engine dying when pulling the clutch in issue.
    One of the steps is to make sure that the clutch disengages fully (which I think that it doesn't)
    Adjusting on the lever worked to a degree, as I think that the clutch works better now and the bike's engine doesn't die every time when repeating the scenario.
    Downside - I run out of adjustment space and the lever is miles away from my fingers.
    I wanted to adjust the pushrod but that is stuck for good.
    Little screw holding the rod was corroded and it rounded of at the first attempt of losing it out.
    I need to get a new pushrod for the lever.
    Anyone knows where to get one?
    Ordering one from Germany for over 20 seems like a silly idea, it's just a glorified screw...
    https://www.ebay.co.uk/itm/CLUTCH-LE...oAAOSwXkNaUAJe
    Thanks as always.
    K.
    May 2007
    Durham U.K.
    Aprilia performance in tamworth.
    Griff sels em.
    Jan 2018
    London
    Thanks for the tip Northern Phil, but unfortunately the one that they sell doesn't have the "flat bit" which presses the clutch sensor switch:
    https://www.apriliaperformance.co.uk...-rsv-98-0.html
    The eBay one does.
    I guess that I will have to go with it unless anyone has any other suggestions?
    K.
    May 2016
    Costa Rica
    There are several Moto Guzzi models with the same master cylinder with clutch switch. Norge, Breva, Griso?
    Dec 2016
    Derbyshire
    Quote Originally Posted by Krystian View Post
    The eBay one does.
    K.
    How often do you start the bike in gear though? You could always buy the one off Griff and link the clutch switch together?
    Sent from my SM-G950F using Tapatalk
    Jan 2018
    London
    I went with the eBay option, sorry but not a big fan of removing safety features for the sake of it - I found it that it will always catch up with you at the least expected moment
    It was delivered very quickly from Germany and it is well made, in case someone else needs to buy one.
    Also - adjusting the clutch pull fixed my low revs issue! (separate thread).
    Thanks for all the advice.
  1. Shiver/DD Service Bulletin: Clutch Lever adjustments
    By shekel in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 09-14-2010, 09:33 AM
  2. Clutch Lever Adjustment Slip
    By RedRider in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 04-27-2010, 02:20 PM
  3. clutch lever adjustment
    By sixfive in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-31-2008, 11:22 AM
  4. clutch lever adjustment
    By y2kmille in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 04-21-2006, 12:07 AM
  5. Clutch Lever Adjustment
    By gi02sl in forum SL1000 Falco Forum (all years)
    Last Post: 08-01-2003, 11:12 AM
