Results 1 to 8 of 8
Thread: Urgent/ service on dash
    Sep 2016
    Uk
    Hi folks, got a 2011 aprc rsv4r & have just fitted a set of samco hoses.. had to remove the throttle bodies to get to those attached to the coolant manifold & when refitting Iím left with a single connector 😆 (see picture) & a urgent/Service message on the dash
    Sep 2016
    Uk
    Sorry re photos, itís the connector between throttle bodies in the 2nd picture
    Sep 2016
    Uk
    I’ve dug up another picture of said connector.. it may not be the culprit but I’m struggling otherwise to find the cause of urgent & service messages on dash..btw she won’t fire(can’t hear fuel pump)Attachment 349073
    Jul 2012
    england
    My initial thought was exhaust valve servo, but why would it be there.
    Did you plug in both sets of throttle bodies, is there a clip on the back of that connector?
    Jul 2012
    england
    make sure your throttlebodies are connected and free to do their open and close test when you key on and do not catch on anything, like that connector wiring for instance.
    Failing that get yourself the guzzidiag free software and find out what the fault code is
    Sep 2016
    Uk
    Quote Originally Posted by ianofbhills View Post
    Thanks for the reply m8, I removed throttle body (front) only but other than tilting it forward to get underneath I don’t remember unplugging anything.... maybe I did (this connector), but forgot!!��
    will hav another look later
    Chris
    Jul 2012
    england
    Sep 2016
    Uk
    Thanks Ian, ‘‘twas exactly that..don’t know how I missed it��
    Ran her up for a bit & noticed a coolant leak on the hose from manifold to thermostat!!
    Here we go again ��
  1. SERVICE on dash after oil change
    By potere in forum 2010-2018 RSV4 - All Variants
    Last Post: 08-28-2011, 03:54 PM
  2. service on dash need to turn off
    By scapaman in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-15-2011, 01:11 PM
  3. Tuono no go "SERVICE" on dash
    By mikesee in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 03-01-2011, 05:42 PM
  4. "SERVICE" on dash. What to do?
    By Todd S in forum SL1000 Falco Forum (all years)
    Last Post: 10-21-2006, 09:15 AM
  5. "service" on dash?
    By fastbydrmike in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 11-22-2003, 12:00 AM
