Results 1 to 10 of 10
Thread: Removed Servo motor, now what...
    apriliaforum Member clutchNthrottle's Avatar
    May 2017
    Harford Co, Maryland
    ... did the rest of you guys do with the connector plug end still on the bike? Just leave it dangling in the elements? ...or a glob of silicone and tuck it with a zip tie?
    2017 Tuono RR
    Jul 2017
    Northwest Indiana
    Packed it with dielectric grease and used a zip tie to neatly stow it away.......
    apriliaforum expert punisher12b's Avatar
    Aug 2008
    Montgomery County MD
    clutch how much of a pain was it? gonna do it this spring when ever SC ships my exhaust
    2017 Tuono RR bone stock
    2003 zx6r track bike..
    E46 project
    lifted 6.0 powerstroke
    Prior
    2013 Diavel
    2001 Falco. Renegade Undertail CF, Derestricted, Mille Swinger, upgraded shock and big boy spring, wire mod, headlight relay, Intergrated Signals.
    1997 900RR
    1993 F2
    Quote Originally Posted by JCG View Post
    That guy behind you is huge, or was it Dr. Banner and you just cut him off!?
    apriliaforum Junkie Blackfin's Avatar
    Jul 2016
    Ontario, Canada
    There's probably a blanking plug for that harness connector. It'd be nice if AF1 could find it and provide it for sale (hint hint...)
    Jul 2017
    Northwest Indiana
    Or just wrap it with electrical tape.......
    May 2016
    Earth
    Get some self amalgamating electrical tape, then will be waterproof.
    Austin, TX
    we just zip tie it up out of the way....never been an issue in 9+ years of the V4 being out...no sealing, no tape, no grease, nothing
    Nov 2017
    Florida
    I cut the thumb off of a rubber glove. Electrical taped the rubber glove thumb to the connector and then zip tied it up and out of the way. It should be water tight and good to go but who knows.
    Nov 2016
    Georgia
    Quote Originally Posted by punisher12b View Post
    I'll answer for clutch since I recently did mine. it's really pretty easy once you remove the cables from muffler the job is half finished. Then you just remove the upper fairing and unbolt and unplug the servo. The hardest part for me was cutting the one zip tie that holds the cables behind the frame. It's hard to see so I wanted to make sure I was cutting the right thing so once I identified the right place to cut I just put the tip of my knife behind it and it popped off.
    May 2017
    Thanx for replies fellas.
    The instructions provided by Akra are pretty comprehensive and included pics, so the biggest pain was exactly as Brilloman said above. The instructions just said pull the cables out from the front, nothing about cutting a zip tie. I tried pulling from the front and back before concluding that theres a zip tie holding things in there. The placement, clearance and angle makes it a super PITA to reach and you really can't see it so you're cutting blind. The fatty T-Rex frame sliders and the fact that I routed the power cable to my radar detector in the same area further complicate matters... Hence I still haven't even pulled my cables out yet... LOL
    2017 Tuono RR
  1. Bought my first Aprilia/Rotax motor now what......
    By CHAPlain in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-09-2013, 08:11 PM
  2. Alright I got the CRG Bar End Mirror...now what?
    By tommy_02RSVR in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-01-2005, 03:27 PM
  3. Removed the carb, now i have a problem
    By Peasnall in forum RS50 Technical
    Last Post: 04-02-2005, 05:02 PM
  4. Now what have you done?
    By PaulZX9R in forum RST1000 Futura (all years)
    Last Post: 01-20-2005, 12:20 PM
  5. Okay, I've got the airbox mod kit, now what?
    By FactoryPilot in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 03-19-2004, 08:51 PM
