Results 1 to 8 of 8
Thread: Reverse speed selection
    Feb 2017
    belgium
    Hello everybody. Please don't pay attention for my English. It was not so good.
    I have a tuono Aprc 2016 with shifter. I have rearset kit installed actuallys with normal selection of spped. I would like to have a reverse selecting speed but the orginal shifter of aprilia run only
    in one way. Can i change it by a shiter 2 way running like this. Thanks for your help.
    apriliaforum Junkie jump-jet's Avatar
    Jul 2012
    Derby UK
    Which rearsets have you fitted? Some rearsets can be changed from normal speed selection (one down, five up) to reverse (one up, five down) without the need to replace the sensor. It all depends on whether you have to change the link rod from push to pull.
    apriliaforum prov-nov Sam Iam's Avatar
    Nov 2017
    College Station, TX.
    Woodcraft makes a GP shift for the stock rearset and available at AF1. I got one for Christmas. If you get this, you only need the kit. You'll need the shortened rod which is offered when you select the product for only the 2017. I believe they also make one for aftermarket rearsets but it may just be the Woodcraft rearset. I didn't go back and look before posting this.
    2017 Aprilia Tuono V4 1100 RR - The dream bike
    2016 Honda CBR500R - The wife's bike
    2015 Honda Stateline VT1300 - The family truckster
    Jan 2014
    Wetcoast, Canada
    I believe he's asking about auto blipper, not GP shift.
    if so, there are kits available, but its not as simple as just replacing the strain sensor. there is an ongoing thread in the rsv forum.
    Feb 2017
    belgium
    Hi
    thanks for your reply. I have fit reverse kit from Gilles tolling and it was not possible to have reverse speed with the original position of the selector
    so i need to reverse this
    and the shifter will be work on pull implusion and not on push implusion.
    Nov 2017
    I feel fairly certain you're asking about a GP shifter. Jump-jet explained what he (and I) think you're asking about. Is this correct? If so, then you need something like this....
    This takes the shift rod from the bottom and moves it to the top which, in essence, will reverse the shift pattern but keep the push-pull on the quick-shifter the same for the bike.
    Feb 2017
    belgium
    yes you are right but i have already instaled gilles tolling rearset kit and this shift dot not wok with it. So the solution is to take a shifter with 2 work direction. in this case the bike receive a information from the shifter when it was running in position pull like in orginal position push.
    Nov 2017
    Quote Originally Posted by kenzoloon View Post
    Sorry man, this is above my level of expertise. I'd suggest maybe contacting AF1 or your dealer in Belgium and ask for guidance. Does Gilles not make what you need for their rearset?
  1. RS250 Challange - reversed gear selection
    By JeremyCondie in forum RS250
    Last Post: 04-10-2015, 10:31 PM
  2. 16/44 combo top speed.
    By scott2ride in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-17-2003, 04:37 PM
  3. legal advice please guys for speeding (especially police )
    By eddie v twin in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-03-2003, 06:49 PM
  4. Aprilia Commercial on Speed
    By angrybobr1 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-20-2003, 12:42 PM
  5. speed?
    By topper in forum Aprilia Owner's Pictures, Videos, and Sounds
    Last Post: 12-26-2002, 10:39 AM
