Results 1 to 9 of 9
Thread: ECU/Exhaust Swap, Bike Wont Start
    Apr 2017
    Sweden
    Elo
    Tuono Factory -17 APRC
    Swapped Exhaust and ECU, done the Handle/Throttle Learning in GuzziDiag.
    The only "problem" on dash is a service alarm regarding TC, which i cant calibrate in the snow.
    Bike does its start procedure and all lights works, so everything seem in order
    But pressing the starter gives the same reaction as to leave the Killswitch at ON, not the case here.
    No clicking noise, doesnt even try to spin the engine.
    Checked all fuses below the seat.
    Current Tuono 1100 Factory -17
    Virago xv - custom project
    past MV brutale 675 -14
    Nov 2017
    Los Angeles
    Side stand down?
    Apr 2017
    Sweden
    Yup, but its in neutral.
    apriliaforum expert plocky's Avatar
    Oct 2015
    Tasmania
    Has the ECU been set up properly by the seller for your bike??
    If AF1 set it up 100% that it is setup & tested correctly for the information you gave them during purchase. Anyone else???
    Is it running the correct map for your bike?
    Is it the correct ECU for your model?
    Take you five minutes to reinstall old ECU & test if bike starts, that should confirm whether it is new ECU prob or not.
    Recheck all connections you undid to change over, especially IMU on back of tank.
    2015(16) RSV4 RR Ascari Black 201HP
    apriliaforum newb Latro's Avatar
    Sep 2017
    Ireland
    Connect GuzziDiag and check for fault errors in particular the active ones.
    '16 Tuono Factory
    United Kingdom
    Changing the ecu on a 2017 bike is not as straight forward as on a 2015. You need to visit the dealer to use PADS in order to commission the ecu correctly.
    Max Lean Angle / Administrator Ed / AF1 Racing's Avatar
    Jun 2003
    Austin, TX
    Quote Originally Posted by RedMacgregor View Post
    Correct, it need to have the units in the ecu set to mph or kph and that must match what the abs unit is programmed to. Has nothing to do with units on the dash. They are not set as sent from Aprilia. We setup the ecus for a diy install, and we set them to mph for USA and Canadian customers unless otherwise noted
    Apr 2017
    Sweden
    Appreciate it
    Gona swap to standard ecu and check first. If race ecu is the problem i Will take it to dealer come spring.
    Happy new year
    apriliaforum Member skeelo221's Avatar
    Jul 2011
    San Diego, CA
    Quote Originally Posted by Dayvid View Post
    Appreciate it
    Happy new year
    Using GuzziDiag what is the map code of the ECU you installed?
  1. bike wont start,exhaust seems to be sucking air in ??
    By rob12770 in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 08-22-2013, 04:03 AM
  2. Urgent help..Bike wont start,petrol leaking by exhaust connecter
    By Jeddy_b in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-07-2008, 08:31 PM
  3. Bike wont start
    By barnesy1977 in forum RS125 Euro-archive
    Last Post: 11-15-2003, 08:41 AM
  4. Bike wont start HELP!!!!!
    By rob mcconnell in forum Pegaso 650 Cube and IE
    Last Post: 09-30-2003, 05:12 AM
  5. Bike wont start
    By r1y2k in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-19-2003, 12:44 PM
